![]() | Home > General > Ride height |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
Usually will ride high for a bit, BTW normal height isapprox 200mm from rim to arch with 20inch wheels. |
| panda Member Since: 17 Jan 2010 Location: london Posts: 702
Thanks shepp
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
It will not (cannot) lower 100% till it's been moved 10m or so after lowering... the wheel track width has to change slightly with ride adjustment... it's probably just under tension/compression RRS gone
