Home > Technical > Sat nav update problems
StevenMcHenry
United Kingdom 2007 Range Rover Sport TDV8 HSE Baltic Blue
I have a RRS 2007. I tried to update my GB maps with genuine discs 2011-2012. Now the sat nav will not display the keyboard to enter data after pressing address/postcode button. Can anyone help please
Post #372845 Sat Feb 09 2013 6:11pm
It may of set itself back to its default country which is belgium i think, go into the settings and set it to the UK. Hope this helps.
Post #372846 Sat Feb 09 2013 6:21pm
Bodsy
Site Sponsor
Yes, you can enter any postcode..... As long as its in Belgium!
Press on the Europe map and select uk. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #372851 Sat Feb 09 2013 7:13pm
57TDV8
2010 Range Rover Sport TDV8 HSE Zermatt Silver
Mine did that when I reset factory defaults to lose 'Home' location, as it says above hit UK on the map & off you go...
...and let me know if I could borrow the disks for my 57 plate TDV8? Wink
Post #372852 Sat Feb 09 2013 7:25pm
shakeapaw
and me to please Wink 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #372892 Sun Feb 10 2013 10:49am
StevenMcHenry
Hi, managed to manually load upgrade from disc by using a code. Sat nav updated software 1070 ? But I still can enter any post code or address as the screen will not move to the alpha numeric keyboard. Any ideas please . Could it be a software glitch in the DVD player software. The battery had gone flat while it was with the previous owners. I put a 2007 sat nav disc in and it all works fine ???
Thanks
Steve I have a RRS 2007. I tried to update my GB maps with genuine discs 2011-2012. Now the sat nav will not display the keyboard to enter data after pressing address/postcode button. Can anyone help please
Post #372905 Sun Feb 10 2013 12:27pm
Dazza
Sat nav
I have a rrs hse 06 i have loaded an up to date disc but only half of the the touch screen options display come on the screen sometimes they appear thrn they go off ,this results in me not being able to use my sat nav any ideas how to. Fix it many thanks
Post #411450 Tue Jan 28 2014 12:26pm
Gary
I'm sure I read somewhere that the system needs rebooting or something when a new disc is added, I bought a new disc from my local indi but he loaded it while I was drinking his coffee Whistle
Post #411451 Tue Jan 28 2014 12:34pm
Dazza
How do you reboot the system
Post #411456 Tue Jan 28 2014 1:17pm
Dazza
Gary how do you re boot system many thanks
Post #411457 Tue Jan 28 2014 1:18pm
jimbg
Thanks
Steve
Did you change the country back to the UK though? Belgium does not need alpha keys for post codes! Whistle 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #411458 Tue Jan 28 2014 1:21pm
Haybale
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I recently updated mine with the 2011 disc as well. I just put in the new disc, let it do its thing for about 10 mins and then changed the default country from Belgium to UK and then I got my postcode search back and everything has worked as it should since!
Post #411461 Tue Jan 28 2014 1:47pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Sane here, new disc in, left it for a bit while it sorted itself out, changed it from Belgium to Uk, worked done ever since.
Post #411473 Tue Jan 28 2014 3:11pm
Dazza
Hi Bodsy,
Can you PM me how much for - Clock On Dash/ SatNav On The Move/3Flash Indicators/ Bluetooth Update for Phonebook and Gearbox Reset for a 06 hse 2.7 rrs
Or were i can go to get the updates sorted
Cheers,
Darren
Post #411616 Wed Jan 29 2014 3:37pm
Dazza
Sat nav software updates
Can anyone help me as regards all softeware updates and the cost please as its driving me mad many thanks darren
Post #413476 Tue Feb 11 2014 1:59pm
