![]() | Home > Technical > Sat nav update problems |
It may of set itself back to its default country which is belgium i think, go into the settings and set it to the UK. Hope this helps. |
Yes, you can enter any postcode..... As long as its in Belgium!
| 57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113
Mine did that when I reset factory defaults to lose 'Home' location, as it says above hit UK on the map & off you go...
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948
and me to please |
| StevenMcHenry Member Since: 09 Feb 2013 Location: Northumberland Posts: 3
Hi, managed to manually load upgrade from disc by using a code. Sat nav updated software 1070 ? But I still can enter any post code or address as the screen will not move to the alpha numeric keyboard. Any ideas please . Could it be a software glitch in the DVD player software. The battery had gone flat while it was with the previous owners. I put a 2007 sat nav disc in and it all works fine ???
| Dazza Member Since: 28 Jan 2014 Location: Pinner Posts: 7
I have a rrs hse 06 i have loaded an up to date disc but only half of the the touch screen options display come on the screen sometimes they appear thrn they go off ,this results in me not being able to use my sat nav any ideas how to. Fix it many thanks |
| Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268
I'm sure I read somewhere that the system needs rebooting or something when a new disc is added, I bought a new disc from my local indi but he loaded it while I was drinking his coffee |
How do you reboot the system |
Gary how do you re boot system many thanks |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924
Did you change the country back to the UK though? Belgium does not need alpha keys for post codes! 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
| Haybale Member Since: 25 Jul 2013 Location: Co Durham Posts: 30
I recently updated mine with the 2011 disc as well. I just put in the new disc, let it do its thing for about 10 mins and then changed the default country from Belgium to UK and then I got my postcode search back and everything has worked as it should since! |
| Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522
Sane here, new disc in, left it for a bit while it sorted itself out, changed it from Belgium to Uk, worked done ever since. |
Hi Bodsy,
Can anyone help me as regards all softeware updates and the cost please as its driving me mad many thanks darren |
| All times are GMT |
