![]() | Home > General > Fan Delay... Help Please |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
My fan (screen blower) fails to start up for a few minutes in the morning...
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
Same here unless I put it on defrost mode. Although I've also had the fan continue to run after the ignition was off and tapped the relay under the bonnet which stopped it immediately. Maybe the two are related and the relay is struggling to switch itself on or off |
I believe it's a feature to stop the car being pumped full of cold air until the heaters are up to temperature. |
I'm sure it's a fault. Can last 3 or 4 minutes. 2022 P440e AB |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
So can mine when it's really cold out there.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Bump....
PegoVix Member Since: 17 Sep 2014 Location: Melksham Posts: 7 ![]() ![]() ![]() |
Hi guys, i have the same problems particularly when it's colder, I replaced the final stage resistor last week and the problem still persists.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4507 ![]() ![]() ![]() |
Try swapping the relay with another. Fairly common problem |
Thank very much for the relay advice, took it out the other day to get a replacement but couldn't get one so put old one back in and since then it's worked fine with no faults. |
Any standard 4 pin relay would do the trick. How long it lasts, of course, will be quality dependant. |
