![]() | Home > In Car Electronics > Aux audio connector and power supply in rear |
| beefbops Member Since: 04 Jan 2012 Location: Prestwick Posts: 46
Yeah your on the right path, I got mine off ebay. It's 3 cables in 1, 1 has jack plug for the aux, 1 has the 30 pin connection for your ipod and the other cable is a usb connection which plugs into a charger (supplied with it) that goes into your cigarette lighter. Think it cost me £9, comes in White or black, I got black goes better with the car.
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690
Ditto. Works very well. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
| iainp100 Member Since: 05 May 2011 Location: saddleworth Posts: 59
Yep I used a Belkin adapter connects via apple connector and has 3.5 mm jack plug and plugs into 12v socket Range rover Sport tdv8 with bas touch
| bobrrs Member Since: 27 Feb 2012 Location: UK Posts: 2
Can you give me a link to an item on ebay? I am not sure I can see the right adapter.
This is what you should see mate
Hey Bobrrs, hope this works....
| scenery Member Since: 21 Jan 2013 Location: richmond Posts: 19
Did you ever sort this out?
Problem solved!
| All times are GMT |
