| RRSPORT.CO.UK | ||
|  | Home > In Car Electronics > Aux audio connector and power supply in rear |
| beefbops Member Since: 04 Jan 2012 Location: Prestwick Posts: 46      | Yeah your on the right path, I got mine off ebay. It's 3 cables in 1, 1 has jack plug for the aux, 1 has the 30 pin connection for your ipod and the other cable is a usb connection which plugs into a charger (supplied with it) that goes into your cigarette lighter. Think it cost me £9, comes in White or black, I got black goes better with the car.
|  Tue Feb 28 2012 7:39pm |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690    | Ditto. Works very well. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
|  Tue Feb 28 2012 7:59pm |
| iainp100 Member Since: 05 May 2011 Location: saddleworth Posts: 59    | Yep I used a Belkin adapter connects via apple connector and has 3.5 mm jack plug and plugs into 12v socket Range rover Sport tdv8 with bas touch
|  Tue Feb 28 2012 9:22pm |
| bobrrs Member Since: 27 Feb 2012 Location: UK Posts: 2      | Can you give me a link to an item on ebay? I am not sure I can see the right adapter.
|  Tue Feb 28 2012 9:58pm |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690    | This is what you should see mate
|  Tue Feb 28 2012 11:05pm |
| beefbops Member Since: 04 Jan 2012 Location: Prestwick Posts: 46      | Hey Bobrrs, hope this works....
|  Thu Mar 01 2012 8:36pm |
| scenery Member Since: 21 Jan 2013 Location: richmond Posts: 19      | Did you ever sort this out?
|  Fri Jan 25 2013 6:57pm |
| scenery Member Since: 21 Jan 2013 Location: richmond Posts: 19      | Problem solved!
|  Wed Jan 30 2013 6:15pm |
| Posting Rules
