Home > Maintenance & Modifications > Temperature Fault ??
steverrs
Scotland 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Hi All,
Over the last few days when driving the temperature gauge doesn’t reach its normal position, if I stop at lights etc the gauge begins to drop back towards cold, if left the needle almost drops back in the blue area.
Could this be a thermostat issue or sensor?? I will be calling the dealer tomorrow but though I would get a little more sense on here first, well hopefully!!
Thanks, Steve
Post #370754 Wed Jan 23 2013 11:37pm
steverrs
Well dealer was helpful, after a two hour wait for a return call I had to call them. The advice given, call LR Assist.
I now have a 3 hour wait before anyone turns up; all I wanted to know was is this fault that needs attention.
A complete waste of a day and still no nearer getting an answer!
Post #370806 Thu Jan 24 2013 1:03pm
It does sound like a thermostat issue - sounds like it might be staying open no matter what the temperature of the circuit. This, of course, is a good thing as it prevents the engine overheating and causing damage e.g. head warping. 2012 SDV6 - it's missing a couple of cylinders
Post #370812 Thu Jan 24 2013 1:24pm
steverrs
Quick update - Coolant system bled and topped up as there may have been air in the system. BUT car must now go to the dealer as mechanic from LR assist is not convinced the issue is resolved as when carrying out a pressure test the pressure was falling as the rpm was increased. When rpm returns to idle pressure returns to normal.
Anyone had anything similar?
Post #370867 Thu Jan 24 2013 8:16pm
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
I only have a problem that the needle stays in the middle, then when it warms up it goes back up to red, but is not overheating.
Then when turning of the car it falls down and stays in the middle.
My mechanic tells me its a faulty cluster, but I dont know ;/ 91 BMW 850CSI
Post #370868 Thu Jan 24 2013 8:19pm
