![]() | Home > Maintenance & Modifications > Temperature Fault ?? |
| steverrs Member Since: 17 Feb 2011 Location: West Lothian or somewhere abroad Posts: 98
Well dealer was helpful, after a two hour wait for a return call I had to call them. The advice given, call LR Assist.
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
It does sound like a thermostat issue - sounds like it might be staying open no matter what the temperature of the circuit. This, of course, is a good thing as it prevents the engine overheating and causing damage e.g. head warping. 2012 SDV6 - it's missing a couple of cylinders
Quick update - Coolant system bled and topped up as there may have been air in the system. BUT car must now go to the dealer as mechanic from LR assist is not convinced the issue is resolved as when carrying out a pressure test the pressure was falling as the rpm was increased. When rpm returns to idle pressure returns to normal.
| Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402
I only have a problem that the needle stays in the middle, then when it warms up it goes back up to red, but is not overheating.
