![]() | Home > Technical > Radweld? |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
I'd get the job done properly myself. If there's still a leak somewhere it needs to be investigated further. |
Perhaps you have a cracked EGR cooler? That's the usual place for losing coolant. Bodsys Brake Bible
Radweld is a bodge; suitable for old nails at the end of their life maybe but certainly not an RRS. Basically its a sludge designed to block small apertures so has habit of blocking important small water passageways and causing problems particularly in heater matrixes. Agree with previous post - find your leak and fix it properly. And if your curry smells of ethylene glycol (a potent poison) suggest you change your supplier |
The old fashioned solution was "two egg whites", because it dries hard when exposed to heat and air - it can actually seal significant seapages.
jakeob Member Since: 21 Nov 2012 Location: cheshire Posts: 64 ![]() ![]() ![]() |
Thanks for the advice,, i'l steer clear of the Radweld. |
