Home > Technical > Radweld?
jakeob
England 2007 Range Rover Sport TDV8 HST Java Black
Radweld?
A few weeks back i had a coolant leek,
Had the thermostat housing replaced and some hoses that were leaking at the ends, Its cured the problem 95% but still need to top up every week,, and i can still smell Antifreez when i park up,(Like curry)
Wondering if i should use some Radweld to finish it off
Post #370120 Sat Jan 19 2013 3:20pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
I'd get the job done properly myself. If there's still a leak somewhere it needs to be investigated further.
Post #370186 Sun Jan 20 2013 10:11am
Bodsy
Site Sponsor
Perhaps you have a cracked EGR cooler? That's the usual place for losing coolant. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #370190 Sun Jan 20 2013 10:51am
Paddi
Radweld is a bodge; suitable for old nails at the end of their life maybe but certainly not an RRS. Basically its a sludge designed to block small apertures so has habit of blocking important small water passageways and causing problems particularly in heater matrixes. Agree with previous post - find your leak and fix it properly. And if your curry smells of ethylene glycol (a potent poison) suggest you change your supplier Smile 2008 MY Java Black TDV8 HSE
Post #370206 Sun Jan 20 2013 2:31pm
drdelrrs
The old fashioned solution was "two egg whites", because it dries hard when exposed to heat and air - it can actually seal significant seapages.
Would I use it in a RRS - probably not unless it was a get-you-home fix.
Post #370224 Sun Jan 20 2013 5:13pm
jakeob
Thanks for the advice,, i'l steer clear of the Radweld.
Post #370227 Sun Jan 20 2013 5:19pm
