![]() | Home > General > HDC fault at startup |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324
hi, i had this when my battery got low. you drive every day? i dont so i hook it up to a charger now and then. when charged to full charge it did nt appear. Otherwise a new battery? |
| Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73
Had the same problem on mine, eventually it would start then immediately stall...had a new battery fitted and no problems since (well with the HDC anyway |
| Coxlong Member Since: 01 Aug 2012 Location: UK Posts: 21 |
Quite a strange one, car's used regularly and never had an issue starting!
| Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259
coxlong What was the outcome as mine has just done the very same |
| 1860Gavin Member Since: 16 Oct 2012 Location: Cumbria Posts: 11
Had same fault in Dec on my SC. Battery check read unservicable. New battery cured fault. |
| madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285
Same here new battery in december hdc fault gone |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Surely worth checking the alternator too in case that's whats causing the poor battery too, no ? ON THE WAY: BMW F21 M140i
Possibly but my friend had the same issue last week Had it checked they said the alternator ( he had the alternator replaced with a recon one 15 months ago by the same company the warrenty was of course out ) so he paid the £220 bill for another alternator guess what still got the hdc so he needs a battery now if he wants to get rid of this message.As everyone knows once started and run you wont get it again untill the car has stood (usually overnight ) it happens on first crank in the morning but yes woth checking the alternator |
| bazalab Member Since: 03 Dec 2010 Location: Lymington, New Forest, Hampshire Posts: 37
Hi All
If the alternator is charging correctly the new battery will cure it |
Thanks Madmackie!
As I've said earlier my car is a 55 plate so it's just 7 yrs old I had the problem new battery sorted what I will say is get the right battery don't be fobbed off if its a diesel it need to be at least 90 amp with a cca of 900( cold crank ampage) if it doesn't have this don't fit it as next year when it's cold you will have the same issue.i got mine off eurocarparts delivered with 3 yr warranty it was 100amp with a cca off 950 for £89 using promo code battery 15. If you need the link let me lnow |
Thanks much appreciated and I will get back to you if needed!
| All times are GMT |
