![]() | Home > General > Are you always in Drive? |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
we had this discussion on freel2
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 ![]() ![]() ![]() |
I've always thought that the torque converter is designed so there's not really any strain on the system when stationary and that constant swapping from D to N would have more of a detrimental effect. This was told to me by a BMW technician but I have no idea if that is based on fact!
I failed my first driving test solely for not putting the manual car into neutral and applying handbrake while stopped at traffic lights. I had waited in 1st gear with clutch and foot brake pressed which was apparently a serious enough error to fail me (zero minor mistakes on my fail sheet after a 40 minute test). The reason given to me was if someone hit my car from behind I could lift my feet off the clutch/brake in shock and hit the car in front.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Sometimes I leave it in drive with the footbrake and sometimes I put it in neutral and use the EPB. It rather depends how long I think I'm going to be stationary.
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Force of habit to pop it into Park. FF 4.4 V8 Soooo looking forward to this bad boy
I'm sure I was taught that the car should always be in gear and if stopped then apply the handbrake too, never have a car out of gear with out the handbrake on Maybe they have changed the rules since i did my test, as the stop start technology requires you to be out of gear and foot off the clutch for it to work |
In terms of mechanical sympathy you're best to leave it in Drive unless you expect to be stationary for more than a couple of minutes.
Not sure if stop/start technology was already out back then and don't remember if there was such a rule even then TBH. I do remember my instructor was equally surprised to see the reason for failure though. Digressed a bit there. Interested in hearing people's thoughts on mechanical reasons for switching or not switching between D and N. |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Of course, if your sport is fitted with Transmission Idle Control then you can leave it in Drive 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
jakeob Member Since: 21 Nov 2012 Location: cheshire Posts: 64 ![]() ![]() ![]() |
I thought it was only OAPs that used the handbrake and went in to neutral Every!! time they pull up |
Coolbanana Member Since: 24 Oct 2012 Location: Buckinghamshire Posts: 38 ![]() ![]() ![]() |
I stick the RRS in Sport Mode and Adaptive Dynamic Mode and it doesn't leave that setting until I turn the car off. Current car: Porsche 911 Carrera S PDK (997.2) Past Car: (MY12) Range Rover Sport HSE SDV6 - Orkney Grey with Almond interior
One of the reasons for not leaving it in drive and standing on the brake pedal is that you end up dazzling the person behind with very bright brake lights, especially at night.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
i only ever put in neutral at traffic lights if the car is still cold, as i can feel the engine labouring slightly, so i let it rev free to help with the warm up 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
From memory, i was taught that if you came to a junction that was a STOP sign then you had to STOP apply the handbrake then select 1st gear ready for pulling out of the junction as soon as it was safe to do so. If it was a give way junction then there was no need to apply the handbrake and you could use clutch control ready for pulling out when safe to do so providing you wasn't going to be sat at the junction all day ![]() Back to the OP question, as said above it all depends how long i'm going to be sat at the lights, i usually apply the EPB then pop it into N and take my foot off the brake, especially at night so not to dazzle the person behind me as also mentioned before (considerate driver me) But when i pull away when the lights have changed i always put my foot on the brake to release the EPB i know you don't have to but i always do. It just doesn't feel right pulling away with the EPB on, i know its designed for that purpose but thats how i do it. ![]() |
