![]() | Home > General > Are you always in Drive? |
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 ![]() ![]() ![]() |
^^^^ Same here. I know I really shouldn't but you hear of issues with the EPB and I'm just a bit lazy to be honest.
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
This is the first auto I've owned, and I spend most if the time popping it into P as it doesn't require the EPB to be applied. However I'm beginning to get into the habit of popping it in to N and using the EPB.
Mike_S Member Since: 03 Dec 2012 Location: Dunstable Posts: 15 ![]() ![]() ![]() |
D for me, unless I'm stopped for a while. I do use the EPB frequently though as I was told with my Jag that not using it caused things to seize |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
![]() ![]() The parking brake is, as the name may indicate, used for when the car is parked. Enroute, D is the correct mode. Shifting between D and N or P while enroute is not required and causes unnesesary wear and tare on the plates. SW Sometimes it is not enough to do our best; sometimes we must do what is required. ![]() Now: 2016 RRS HSE DYNAMIC 3.0 TDV6 |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
I put it in N if stopped more than a few seconds and EPB on |
In D for me, I may apply the EPB if I'm sat for a while at a particular set of light and feeling curteous to the driver behind, but in 95% of the cases, I stay in D with foot on the brake. ON THE WAY: BMW F21 M140i
