![]() | Home > In Car Electronics > Rear demister / defroster |
Same here and front screen heating not working either. That post about getting to the corroded connection under the rear spoiler was something like: open the rear hatch and remove three bolts and then open the glass section only and remove three Torx bolts being careful to avoid scratching the edge of the roof. I can't find post as something has changed on search facility and can't seem to use Boolean technique??? Good luck. I've checked fuses and all OK. Charging battery with trusty CTEK in case that helps. Too chuffing cold to spend more time on it today! 2008 MY Java Black TDV8 HSE
Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70 ![]() ![]() ![]() |
Thanks for that info. I'm going to try and dismantle the upper tailgate area either tomorrow or Monday. I've got the use of my dads garage so I'm not outside in the cold!
Good luck! Just had a quick check and there are 3 bolts visible with main tailgate open and 2 biggish torx bolts visible with the glass section open. After charging the battery with CTEK smart charger yesterday and pulling and checking all the fuses my heated front screen mysteriously worked this morning: all the frost started melting and sliding down the screen after about 30 seconds or so |
Thanks for checking for me. I haven't had chance to do anything with it today. We spent the day out in it and from when I got in this morning, the front heated screen was a god send. Mine had been stood for 3 days but after about a minute and half it cleared and during the warm up I could see the steam coming from it. Also the fuel burning heater was working as I got a bit of smoke/steam from under the car too.
NDR311 Member Since: 01 Dec 2012 Location: Aberdeenshire Posts: 1 ![]() ![]() ![]() |
My heated rear screen does not work and the upper window doesn't release. Fuses ok. Tailgate opens and wiper/washer works. Anyone experieced similar? Local (non-franchised garage thought "relay" although they've not looked at it. Warranty out by 1 month and I'm not too keen on the £110/hr labour charge at the local dealer to go troubleshooting.... |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
NDR, your tailgate release switch is probably corroded. Common problem. Remove the rubber cover and have a look at the switch underneath. These are known to create a short and drain the battery over night.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9100 ![]() ![]() ![]() |
Kav, the rear quarterlights don't demist. Those lines are aerials, not demisting wires... 2012 SDV6 - it's missing a couple of cylinders
Thanks mate - I'm a sausage |
In Bobby's gallery - Removal of rear spoiler.
Nice one Paddi. There is also a video on YouTube (link is in definitive how to thread)...
Ok, mine is all sorted |
Thanks for that kav
Kav - |
