![]() | Home > Maintenance & Modifications > Osr door wont open on a rangerover sport 2006 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
Failed door latch, not unlocking. Fairly common, and reasonably cheap to fix |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
As above, rear door actuator. I had this problem on mine. If I remember correctly you can get the door open by getting someone inside the car to hold the unlock button whilst opening the door handle. Next step is to replace the actuator. Part cost about £70 I think from the stealers. Changing the part is a bit fiddly but achievable, probably need to get a few clips for the door card as they can snap. I can't remember exactly where I found it, but there is a detailed guide somewhere on the internet, just google away......... |
I find that if you press the unlock button on the remote repeatedly, while at the same time, pull the door handle repeatedly, this is normally enough to get the door open. Takes a bit of practice, but I have changed loads of latches on RRS/D3's and 9 times out of 10, that works for me |
