Home > Maintenance & Modifications > Osr door wont open on a rangerover sport 2006
jay340v
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Siberian Silver
Hi sorry if this has been asked but i couldnt see a search function on the forum.
The osr door wont open as it is locked and wont open with the remote or the button inside car for the central locking.Any sugestions .
Regards Jason
Post #364563 Mon Nov 26 2012 7:30pm
Disco_Mikey
Failed door latch, not unlocking. Fairly common, and reasonably cheap to fix Thumbs Up
Post #364566 Mon Nov 26 2012 8:23pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
As above, rear door actuator. I had this problem on mine. If I remember correctly you can get the door open by getting someone inside the car to hold the unlock button whilst opening the door handle. Next step is to replace the actuator. Part cost about £70 I think from the stealers. Changing the part is a bit fiddly but achievable, probably need to get a few clips for the door card as they can snap. I can't remember exactly where I found it, but there is a detailed guide somewhere on the internet, just google away.........
Post #364596 Mon Nov 26 2012 11:54pm
Disco_Mikey
I find that if you press the unlock button on the remote repeatedly, while at the same time, pull the door handle repeatedly, this is normally enough to get the door open. Takes a bit of practice, but I have changed loads of latches on RRS/D3's and 9 times out of 10, that works for me Thumbs Up
Post #364605 Tue Nov 27 2012 7:44am
