![]() | Home > General > Drivers swimming pool |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 62 ![]() ![]() |
Cheers Andy door seal is new also the outer seal to the glass is new |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Has any work been done on the door at all? Wondering if the plastic sheets that seals the inside might be letter water in behind the door card
bigphil99 Member Since: 14 Dec 2011 Location: N. Ireland Posts: 17 ![]() ![]() |
I had this issue with mine although definatly not as much water. I fixed it with this http://www.rrsport.co.uk/forum/topic20562....trim+water
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
From the questions i asked in earlier postings i was trring to figure out if the door membrane had been messed about with and not put back together correctly. If you've had a new window regulator, lock or wing mirror then it's likely that the membrane wasn't put back together properly.
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I had exactly the same problem last year, soaking wet drivers floor mat, searched all over and couldn't find the source of the water. I dried it all out and touch wood it has never happened again! |
The power of hope pleased yours is ok I find my self a bit more sceptical.
Hello mate,
