![]() | Home > General > Drivers swimming pool |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Sunroof drain tubes blocked is my guess
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Your sunroof drainage pipe is blocked. This post explains all
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 62 ![]() ![]() |
Morning all
Have you tried pouring water through the drain tube to make sure it comes out the other end? I believe there is a 90 degree join which might have come undone.
Just removed door trim all grommets in place
Not sure how to lift carpet mate, never done it.
Nothing to dash except a new screen but the carpet was wet before that
Try all 4 corners... |
Tried all 4 they are clear there are 2 grommets in the front drivers footwell in place it's like a mystery the carpet above the footrest is dry along the console dry could it come in from the loom connector to the front door
Been locking around D3 forum sum guys have had problems with the loom connector to the drivers door that's in the right area to get water into the loom recess??? |
It'll be your pollen filter which would have been damaged when the new windscreen was fitted 2005 Zambezi TDV6 - Gone but not forgotten
VA, wouldn't that make the puddle in the passenger side?
I agree I wish people won't go on auto pilot when they see a question trying to be helpful left is left right is right
