| RRSPORT.CO.UK | ||
|  | Home > General > AUX input - broken tip of cable |
| broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 62   | Using a plastic tool prise the unit up to release it . Up plug it it has some very small torch screws holding it together  carefully separate the case there is an extra screw at the bottom
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146     | Thank you for your reply. Will try this afternoon and let you know. Range Rover Vogue ‘17 TDV6
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146     | I managed to remove the whole assembly and it make it easier to try to remove the broken connector inside the aux but I am stuck there...can't get it out...
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916   | Have you tried a powerful magnet possibly using something thin to connect it to the end?
| broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 62   | In the worst case you just heat the connector with a soldering iron to this will release it and the you can push it out.
| CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59   | loctite? try to glue it and pull | ||
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146     | Well, thanks to your help, I've managed to remove the broken tipe of the aux cable but... broke the plug in the process.... I ended up lifting a new unit from a website...
| gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63   | I had the same problem and solved it by drilling the 3.5mm pin with 1mm drill out. Put the drill in the very center of pin which is plastic and soft. Drilled slow speed until drill stuck in plastic and then popped them both together out. Took me 1min to solve ! | ||
| Posting Rules
