Home > General > AUX input - broken tip of cable
Jimmy_75000
Hello,
Does anyone has an idea on how I can remove the top tip of the cable plugged into the AUX input at the back of the central consol? The tip has broken inside the plug... Crying or Very sad Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #363925 Wed Nov 21 2012 12:48pm
broncoupe
Using a plastic tool prise the unit up to release it . Up plug it it has some very small torch screws holding it together carefully separate the case there is an extra screw at the bottom
Now you have 2 boards which are joined but will remove now just use a small screw driver or pliers to remove in the worst case a soldering iron to unsolder the connector all sounds far harder than it is
Will try and post a picture
If you don't want to do it send the unit to me and I will do it for you as long as you cover postage
Regards
Post #364293 Sat Nov 24 2012 10:14am
Jimmy_75000
Thank you for your reply. Will try this afternoon and let you know. Range Rover Vogue ‘17 TDV6
Post #364298 Sat Nov 24 2012 10:53am
Jimmy_75000
I managed to remove the whole assembly and it make it easier to try to remove the broken connector inside the aux but I am stuck there...can't get it out...
Thanks for the info, it was great but that tiny piece of metal won't move... Range Rover Vogue ‘17 TDV6
Post #364305 Sat Nov 24 2012 11:43am
mse
Have you tried a powerful magnet possibly using something thin to connect it to the end?
Ive pulled a jack out in that way before - however, i suppose its down to how grippy the socket is Mike
2014 Facelift Discovery
Post #364307 Sat Nov 24 2012 12:12pm
broncoupe
In the worst case you just heat the connector with a soldering iron to this will release it and the you can push it out.
I have defiantly done it myself so it can be done just be patient with it
If you poke in the whole to much from the top you will damage the small connectors inside
Post #364313 Sat Nov 24 2012 2:53pm
CUCO
Spain
loctite? try to glue it and pull
Post #364380 Sun Nov 25 2012 3:25pm
Jimmy_75000
Well, thanks to your help, I've managed to remove the broken tipe of the aux cable but... broke the plug in the process.... I ended up lifting a new unit from a website...
Thank you all! Range Rover Vogue ‘17 TDV6
Post #364442 Mon Nov 26 2012 8:33am
gruodiz
Lithuania
I had the same problem and solved it by drilling the 3.5mm pin with 1mm drill out. Put the drill in the very center of pin which is plastic and soft. Drilled slow speed until drill stuck in plastic and then popped them both together out. Took me 1min to solve !
Post #370178 Sat Jan 19 2013 10:08pm
