![]() | Home > Technical > cooling system |
Depends how badly they are leaking, but normally with a leaking cooler, you get a coolant loss, with no visible leaks, and sometimes some white smoke out of the rear.
| maddie Member Since: 10 Jan 2011 Location: HERTFORDSHIRE Posts: 6
Thanks for your info going to have a snif test done that will at least say either coolers or head gasket have losts
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Mine is going in next week for another starter motor issue (had a new one fitted earlier this year!) and I've also asked them to look at some coolant loss. Looking at Disco-Mikey's point about loss with no leaks etc, I'm guessing it'll be an EGR cooler issue. 2012 SDV6 - it's missing a couple of cylinders
Hope it is the coolers a bit less cash to shell out. JEFF GALE |
I'm hoping it'll be covered by the warranty... 2012 SDV6 - it's missing a couple of cylinders
