Home > Wheels & Tyres > Profiles
Tre4
2011 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Profiles
I was wondering how much of a difference to the speedo, odo, gearing and anything else technical, having a different profile size makes.
My standard fit tyres , on 20' rims are 275/40/20, looking in the handbook for winter tyre spec and it says 255/50/20. Does that increase of 5 make a difference and if not, how big a difference can the vehicle accept either +/- without it throwing a wobbly?
The standard tyre profile sometimes looks a bit too 'low profile' for the size of vehicle (I know it's a 'sport'), could I for example fit 50's with no side effects?
Thanks
Post #361137 Mon Oct 29 2012 12:34am
oldcro
Scotland
Google "tyre sizes" and you'll find a selection of tyre size calculating tools which will give all the info you are looking for.
The handbooks do have errors so common sense is required as Land Rover seem very reluctant to admit to or correct obvious typo mistakes.
Post #361143 Mon Oct 29 2012 2:16am
I wouldn't worry too much about the speedo being out a little bit, you will find its already out by 3mph on your standard tyres @ 30 mph and out by 4 mph @ 70. Whistle
Post #361157 Mon Oct 29 2012 9:47am
The car won't care what profile you fit just so long as you fit the same on each corner. The speedo / trip computer will read incorrectly but that's an issue for you, not the car Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #361177 Mon Oct 29 2012 12:13pm
mse
You would be surprised how accurate the range rover speed limit is - it has the minimum required error (they all have to over-read so indicated 30 is a little less (10%) actual) Mike
2014 Facelift Discovery
Post #361204 Mon Oct 29 2012 3:55pm
So why can't they get it spot on Question if they can manage to get it to read 10% over Banging Head
Post #361205 Mon Oct 29 2012 3:58pm
They don't have to over-read but they absolutely must not under-read.
As it's impossible to make sure they remain accurate for the entire life of the vehicle (unless, like some police vehicles, you have the speedo calibrated at regular intervals) the easiest answer to have the law allow an over-read tolerance and build them within that tolerance. 2012 SDV6 - it's missing a couple of cylinders
Post #361207 Mon Oct 29 2012 4:24pm
Surely then, they could make it part of the service schedule then or make it part of an mot test, Confused Its not that hard to do, they manage to do it for HGV's. I know many police forces allow the speed limit + 10% + 2mph max.
Post #361209 Mon Oct 29 2012 4:34pm
mse
Thats very true and its thus its standard practice to carry 10% error Mike
Post #361210 Mon Oct 29 2012 4:40pm
mse
Some of that is also about not being drawn into the marginal cases imagine not having a 10% error on your speedo and a strict speed enforcement + a few minor errors and you would need to be exactly correct on the speed Mike
Post #361213 Mon Oct 29 2012 4:42pm
One word: money
Imagine the outcry if the Govt told motorists they'd have to pay for a speedo calibration once a year or every time they changed tyres which ever was sooner.
They system allows for the inherent tolerances in the tyre/speedo combination. If they asked for the speedo to be spot on and it could be showed to under reading at a court case then someone could get off a charge - or even whole groups of people would get off. So the system says the speedo must read between X and X + 10% where X is the indicated speed so for 60mph your speedo can read anything between 60 and 66 mph. To avoid erroneous court cases, everyone sets them up to be near the top of that range because that's the "safest" way to do it.
The ACPO guidelines for speeding offenses are just a way of limiting police work loads and preventing turning every driver in to a criminal... 2012 SDV6 - it's missing a couple of cylinders
Post #361214 Mon Oct 29 2012 4:44pm
I suppose when you explain it like that, i guess it makes sense Thumbs Up
Post #361216 Mon Oct 29 2012 4:48pm
with my new 20's my speedo is almost spot on (according to the radar speed display thingy in the village) RRS gone
Post #361218 Mon Oct 29 2012 4:55pm
^^^ so it reads 70mph as you'rebombing through the village, the same as your speedo Whistle Rolling with laughter ON THE WAY: BMW F21 M140i
Post #361227 Mon Oct 29 2012 5:40pm
*just* 70? Wink RRS gone
Post #361229 Mon Oct 29 2012 5:43pm
