![]() | Home > Wheels & Tyres > Profiles |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
Google "tyre sizes" and you'll find a selection of tyre size calculating tools which will give all the info you are looking for.
I wouldn't worry too much about the speedo being out a little bit, you will find its already out by 3mph on your standard tyres @ 30 mph and out by 4 mph @ 70. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9069 ![]() ![]() ![]() |
The car won't care what profile you fit just so long as you fit the same on each corner. The speedo / trip computer will read incorrectly but that's an issue for you, not the car |
You would be surprised how accurate the range rover speed limit is - it has the minimum required error (they all have to over-read so indicated 30 is a little less (10%) actual) Mike
So why can't they get it spot on |
They don't have to over-read but they absolutely must not under-read.
Surely then, they could make it part of the service schedule then or make it part of an mot test, |
Thats very true and its thus its standard practice to carry 10% error Mike 2014 Facelift Discovery |
Some of that is also about not being drawn into the marginal cases imagine not having a 10% error on your speedo and a strict speed enforcement + a few minor errors and you would need to be exactly correct on the speed Mike 2014 Facelift Discovery |
One word: money
I suppose when you explain it like that, i guess it makes sense |
with my new 20's my speedo is almost spot on (according to the radar speed display thingy in the village) RRS gone
^^^ so it reads 70mph as you'rebombing through the village, the same as your speedo |
*just* 70? |
