Home > Technical > Brembo fitting on hse
Jonesyscoob
Does anyone know if a set of brembo front calipers from a 2009 hse s/c will fit a 2006 hse obviously swapping to the bigger discs aswell?
Post #360424 Mon Oct 22 2012 3:10pm
Will depend what wheels you have. I believe there are only a couple of styles that are compatible with the larger calipers Confused ON THE WAY: BMW F21 M140i
Post #360427 Mon Oct 22 2012 3:11pm
Jonesyscoob
Not sure of make but they are 22" but hoping to swap to the hst wheels? What other styles will fit? Are the calipers a straight swap between the models that was my main concern
Thanks
Post #360435 Mon Oct 22 2012 3:41pm
Ah, in which case you should have plenty of room. Wasn't sure if you were running 19" standard HSE's Smile
I'll let someone more technically able than myself comment re if it's a straight forward swap or not. Embarassed ON THE WAY: BMW F21 M140i
Post #360442 Mon Oct 22 2012 3:51pm
Endjin
Scotland
My previous RRS HSE (2007) had factory fit 19" Y spoked wheels (same look as on the car at the top left on this forums header) and it had factory fit Brembo's on the front wheels. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #360453 Mon Oct 22 2012 4:39pm
Bradders
They look like the 20"s to me. Question
I recall some 19"s fit and some don't. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #360476 Mon Oct 22 2012 7:08pm
Kensta
The Calipers and larger discs will bolt straight on no problem at all, only mod I had to do was fit 3mm spacers behind my 22" wheels for the brake clearance. Thumbs Up Java black 2006
Post #360537 Mon Oct 22 2012 11:00pm
Jonesyscoob
Thanks for that what wheels do you have?
Post #360549 Tue Oct 23 2012 8:01am
Endjin
Scotland
Mine were the 19s and did have Brembo's, which was my main point. I know the ones on the pic look like the 20's but I just pointed the pic out as an indication of the "style" of wheel as this is the same style as my 19s were. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #360573 Tue Oct 23 2012 12:28pm
Kensta
Supersport 22" reps Java black 2006
Post #360586 Tue Oct 23 2012 2:49pm
Mitchmx
i won a set of calipers on ebay the otherday, gonna go pick them up today Very Happy never checked that my wheels would be big enough first tho. i got 20" stormers so fingers crossed ill be ok. Bow down
ill let you know how i get on fitting them later tonight. Thumbs Up
Post #360684 Wed Oct 24 2012 10:12am
Jonesyscoob
How did the fitting go?
Post #361020 Sat Oct 27 2012 7:29am
Mitchmx
Not the best. There was no pads with them so I'm after a set.
Do you think green stuff pads or brembo pads?
Also the calipers are black and I'm in two minds wether to get them power coated red or not? My cars black so red will stand out but might look.... Tacky??
Post #361022 Sat Oct 27 2012 8:54am
Jonesyscoob
I have the same dilemma! I'm swapping from years of impreza ownership and have always used ebc pads, but have heard mixed reviews on rr pads, car is also black so unsure on colour aswell!!
Post #361025 Sat Oct 27 2012 9:38am
From an ex P1 owner myself i would use brembo pads, they are tried and tested on the sport with great feedback Thumbs Up If you want to see how red calipers look on a black sport search awd range rover sport another subaru ex owner on here, his sport looks Cool with red calipers, there is also a step by step guide on here on how to paint them. Thumbs Up
Post #361029 Sat Oct 27 2012 10:33am
