![]() | Home > Technical > Brembo fitting on hse |
Will depend what wheels you have. I believe there are only a couple of styles that are compatible with the larger calipers |
Jonesyscoob Member Since: 21 Oct 2012 Location: Birmingham Posts: 95 ![]() ![]() |
Not sure of make but they are 22" but hoping to swap to the hst wheels? What other styles will fit? Are the calipers a straight swap between the models that was my main concern
Ah, in which case you should have plenty of room. Wasn't sure if you were running 19" standard HSE's |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
My previous RRS HSE (2007) had factory fit 19" Y spoked wheels (same look as on the car at the top left on this forums header) and it had factory fit Brembo's on the front wheels. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
They look like the 20"s to me. ![]() I recall some 19"s fit and some don't. FF 4.4 V8 Soooo looking forward to this bad boy Ex 2006 RRS SC - garbage Ex 2016 135i M Sport - dream car Ex 2003 RS6 Avant - piece of cr*p Ex 2014 320d X Drive, M Sport Touring - ok I guess Ex 2007 RRS TDV8 - bloody loved it EX 2007 FL2 XS - not so bad |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 702 ![]() ![]() ![]() |
The Calipers and larger discs will bolt straight on no problem at all, only mod I had to do was fit 3mm spacers behind my 22" wheels for the brake clearance. ![]() |
Thanks for that what wheels do you have? |
Mine were the 19s and did have Brembo's, which was my main point. I know the ones on the pic look like the 20's but I just pointed the pic out as an indication of the "style" of wheel as this is the same style as my 19s were. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Supersport 22" reps Java black 2006 |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 ![]() ![]() |
i won a set of calipers on ebay the otherday, gonna go pick them up today |
How did the fitting go? |
Not the best. There was no pads with them so I'm after a set.
I have the same dilemma! I'm swapping from years of impreza ownership and have always used ebc pads, but have heard mixed reviews on rr pads, car is also black so unsure on colour aswell!! |
From an ex P1 owner myself i would use brembo pads, they are tried and tested on the sport with great feedback |
