![]() | Home > General > Nokia 6230 & RRS |
I was hoping for a little help. I have just bought the cradle for my Nokia 6230 but how do I get the phone book from the nokia to the car? I'm probably missing something but I thought that this is possible. Everything else works perfectly.
| MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598
Take a look at this pdf file.... full instructions for phone use..hope this helps:-
Biggles
| Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916
Have you paired your phone the bluetooth way. Even though bluetooth does not have to be on for the cradle connection to work it may be worth a try.
I have had the phone previously connected via bluetooth so when my wife gets back with the RRS (yes I know I shouldn't let her drive it) I will switch the bluetooth off and put it back in the cradle and see what happens. (fingers crossed) 2005 Zambezi TDV6 - Gone but not forgotten
The phone book synch ONLY works via the cradle. And as Biggles says, it should "just work" as soon as you connect the phone into the cradle. Do you actually get a "Phone connected" message on the stereo screen when you fit the phone into the cradle? I wonder if the cradle is correctly fitted into place?
Still no luck. I have switched the bluetooth off on the phone. Is there a system reset on the RRS? 2005 Zambezi TDV6 - Gone but not forgotten
Hmm... I take it all the other functions of the PTI work ok? You can still make/receive calls over the cradle and via Bluetooth? Your only problem is with the address book?
shmoogle you are correct .
Will try the above options however after I made a call earlier all seemed to be working, but when I stopped and started the car again 10 minutes later the same problem is happening - very strange |
| RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589
Sorry to be the fly in the ointment but my 6230 is set to use the phone memory, I have nothing on the SIM at all.
I have to agree with RRUK, I use both sim and phone memory to store numbers and have no problems with connection. Are you sure it is a 6230 and not a 6230i the latter is not supported yet. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Landrover also advocate that only certain software versions of the 6230 OS work with the PTI interface. However, my phone is not on the 'correct' version but still works ok. You can find this list on the Ladrover website or if you do a search on this forum, no doubt someone has posted it before.
I have all the correct software and the correct phone. I will be trying another Nokia 6230 tomorrow so fingers crossed. The very nice people at Land Rover had the gall to say that the system is not designed to read the phonebook from the phone! 2005 Zambezi TDV6 - Gone but not forgotten
| All times are GMT |
