Home > General > Non-standard battery kills alternator - true or false?
drdelrrs
Has anyone of heard this ...
TDV8 (22,000mls) went in for non-orginal battery to be replaced under warranty. In the course of changing it the technician decided the alternator was u/s. He believes this is because the non-OE battery had different characteristics to the Land Rover unit and so the 'Smart Charging' system was not sensing the voltage and ampage correctly and this has blown the alternator's little brain.
If this is true then be careful fitting aftermarket batteries and possible impact and warranty issues if the alternator goes t-ts up.
Not sure I believe this as I didn't know the RR Sport TDV8 had the smart charging system -I thought it was just introduced on the Evoque and is some form of regenerative system.
Anyone heard this one before and can confirm if and when 'smart charging' was brought in on the Sport or are we talking b--s--t?
Post #354120 Sat Aug 18 2012 3:22pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
sounds like b o l l ock s - is it a Stratstones by any chance? ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #354128 Sat Aug 18 2012 6:49pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #354130 Sat Aug 18 2012 7:35pm
SingeRRS
Absolute rubbish - check the ampere hour rating of the two batteries and unless the non OE battery is massively higher (I.e 50% plus which I doubt) the charging current would be virtually identical - and certainly no more than the load on the alternator of running a flat OE battery with the lights and other electrical loads on the car.
I really, really hate these idiotic 'technicians' who spin this cr&p. Good luck
Post #354138 Sat Aug 18 2012 10:49pm
drdelrrs
Looks like we are all agreed its b---s--t.
Unless one of our honest dealers can prove us wrong; just for the hell of it I might just ask JLR.
Post #354157 Sun Aug 19 2012 2:39pm
Bodsy
Site Sponsor
JLR reSponse would be that they only recommend the LR one.
I'm sure the battery manufacturer of the none oe one would be interested to hear about this....
What year is your rrs? Battery should be covered same as the car. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #354158 Sun Aug 19 2012 2:42pm
rrsboy
so.. is this confirming it IS a s h it stones?
Whistle
EDIT: they once told me the tolerance between the air suspension on each corner of the car, when on the flat, was.. wait for it... 30% of height value
30%
Shocked ============
Post #354164 Sun Aug 19 2012 6:37pm
drdelrrs
It ain't Stratstone.
Post #354172 Sun Aug 19 2012 8:58pm
rrsboy
is it another Pendragon company (Pendragon own S h it stone) http://en.wikipedia.org/wiki/Pendragon_PLC...and_brands ============
Post #354174 Sun Aug 19 2012 9:17pm
drdelrrs
My 'situation' is ongoing.
I spotted a few problems when I test drove the car that was after it had been pre-Sales inspected and serviced.
Also since taking delivery under a month ago it has been in for warranty work 3 times - the issue with the batteryand alternator being the latest.
Since I am considering rejecting the car I'll shy away from 'naming and shaming' for the moment and see how it pans out.
Post #354198 Mon Aug 20 2012 10:25am
SRE
Spain
You should not have a problem as long as you use a lead calcium battery, if you fit a lead accid battery you may find it plays up with Land Rovers (Smart / CAN controlled) Charging System
Petrol Models
Type: Maintenance free lead calcium
Capacity: 690 amps - 75 amp/hour
Reserve Capacity: 150 minutes @ 25 amps
Tractor juice drinkers
Capacity: 825 amps - 90 amp/hour
Reserve Capacity: 190 minutes @ 25 amps In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #354219 Mon Aug 20 2012 1:39pm
drdelrrs
Yep.
Although they are all 'lead / acid' the 'calcium' battery has coated plates to increase starting power and longevity. I think a calcium battery needs to be charged at 15v.
Post #354278 Mon Aug 20 2012 9:34pm
