Home > General > Cutting out at low speed....
Awk man
2007 Range Rover Sport 4.4 V8 HSE Santorini Black
Hi can any on help, I have a 2007 4.4 v8 sport, it has FSH but it keeps cutting out at low speed/ braking, it starts straigt away.
It has been checked and nothing has come up. Could it be a sensor or electrical ?
Hope someone can assist...
Thanks
Post #353947 Thu Aug 16 2012 9:00pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
do you have a warranty? ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #353991 Fri Aug 17 2012 9:29am
Awk man
Hi yes I have warranty, but they can't find anything wrong. Nothing is showing when they do the diagnostics.
Post #354002 Fri Aug 17 2012 10:53am
have you tried banging some RedEx in the tank? RRS gone
Post #354006 Fri Aug 17 2012 11:07am
You've not run it on fumes have you and sucked up some crap from the bottom of the tank Question ON THE WAY: BMW F21 M140i
Post #354014 Fri Aug 17 2012 11:22am
simple1
Running the tank low or additive won't resolve this. Is the vehicle won't idle intermittently,ore likely to be fault in idle control than dirt in system which if the case would give other symptoms like misfire. Usual cause of this is vacuum leak, which doesn't always show as a diagnostic fault code. Find somebody with smoke tester, and check this first. I'd find yourself a new garage too, unless they haven't been able to replicate the fault Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #354018 Fri Aug 17 2012 11:59am
^^^ You mis understood me, I was saying 'had he' run it on fumes, not advising him to do so Wink Thumbs Up ON THE WAY: BMW F21 M140i
Post #354019 Fri Aug 17 2012 12:19pm
simple1
Mmmm.... Bite tongue... Try reading what's written, badly admittedly rather than what you think you read Rolling Eyes As I said, dirt or even water in fuel system will not cause intermittent stalling and would be accompanied by other symptoms. Modern fuel systems have at least two filters before main paper fuel filter. Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #354022 Fri Aug 17 2012 12:31pm
I only suggested RedEx because the old man's Audi cuts out/stalls at low revs, the dealer cannot find anything wrong with it and say it's fine... anyway... a treatment of |RedEx and it's sorted... and now he just gives it a does every 6 months otherwise the symptoms return. RRS gone
Post #354026 Fri Aug 17 2012 12:39pm
Thumbs Up Embarassed Laughing ON THE WAY: BMW F21 M140i
Post #354032 Fri Aug 17 2012 12:50pm
baxc
check your brake pedal switch if this is faulty it could be an electrical issue thats causing it to cut out
Post #354053 Fri Aug 17 2012 3:07pm
BAck in the day, my Pug Gti would do this too. Turned out to be a blocked crankcase breather pipe. No idea if that's applicable in a newer engine but might be something to check. 2012 SDV6 - it's missing a couple of cylinders
Post #354061 Fri Aug 17 2012 3:46pm
