![]() | Home > General > Cutting out at low speed.... |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
do you have a warranty? ============
Awk man Member Since: 13 Aug 2012 Location: Shropshire uk Posts: 3 ![]() ![]() |
Hi yes I have warranty, but they can't find anything wrong. Nothing is showing when they do the diagnostics. |
have you tried banging some RedEx in the tank? RRS gone
You've not run it on fumes have you and sucked up some crap from the bottom of the tank |
Running the tank low or additive won't resolve this. Is the vehicle won't idle intermittently,ore likely to be fault in idle control than dirt in system which if the case would give other symptoms like misfire. Usual cause of this is vacuum leak, which doesn't always show as a diagnostic fault code. Find somebody with smoke tester, and check this first. I'd find yourself a new garage too, unless they haven't been able to replicate the fault |
^^^ You mis understood me, I was saying 'had he' run it on fumes, not advising him to do so |
Mmmm.... Bite tongue... Try reading what's written, badly admittedly rather than what you think you read |
I only suggested RedEx because the old man's Audi cuts out/stalls at low revs, the dealer cannot find anything wrong with it and say it's fine... anyway... a treatment of |RedEx and it's sorted... and now he just gives it a does every 6 months otherwise the symptoms return. RRS gone
![]() ![]() ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
check your brake pedal switch if this is faulty it could be an electrical issue thats causing it to cut out |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
BAck in the day, my Pug Gti would do this too. Turned out to be a blocked crankcase breather pipe. No idea if that's applicable in a newer engine but might be something to check. 2012 SDV6 - it's missing a couple of cylinders
