Home > Maintenance & Modifications > Surely it shouldn't be this bad!!!
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Bought some blanking plates for the egr valves recently on my 55 2.7 tdv6. When I removed the bolts I was amazed to see how corroded they were, at least the three that I could remove!! They had almost rotted through in places and I was very lucky to get them out without snapping. The last bolt rounded off so I need to tackle that one again. Does anyone know why they'd be so badly corroded, and anyone got any advice as to what to replace them with, I used some random bolts I had in my toolbox as a temp measure but not sure if I need to replace with landrover ones, though judging by the state of what I removed maybe best not to! On a positive note although I only managed to blank off one valve this has massively improved responsiveness and my mpg has improved by about 2 mpg.
Post #351228 Fri Jul 20 2012 12:55pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
You have a LR customer care member now, well done Tony Bow down Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #351234 Fri Jul 20 2012 2:23pm
Texstar
Tony, it's fairly normal for these to corrode, I bought a few of them, and replaced them when I changed an EGR valve a few weeks back, I put some copperslip on the new ones, in case I ever have to remove them again,(fairly likely Whistle ). Pt no for these bolts is RYG500220 for a 55 plate (same as mine). Thumbs Up RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #351287 Fri Jul 20 2012 8:03pm
Tony666
Thanks for that, just picked some up from my local friendly Stratstone in Cardiff, took 3 calls and 25 mins on hold to establish if they had some and then charged 4 x the price that they were available online for (same manufacturer), cheers Landrover Laughing Still trying to get one of the rusted rounded bolts out, made a right mess of it, anyone used any of the 'Grip Sockets' for rounded bolts before??
Post #351412 Sun Jul 22 2012 7:48am
mse
Agreed this is fairly common Mike
2014 Facelift Discovery
Post #351433 Sun Jul 22 2012 11:16am
mikey7985
Wales 2009 Range Rover Sport TDV8 HST Stornoway Grey
Can you not spot weld another nut or somthing onto that rounded one? 2009 3.6 TDV8 HST
Post #351731 Tue Jul 24 2012 10:22pm
Tony666
Thanks for the advice but space is a bit tight and I have neither the knowledge or equipment for welding Embarassed I ordered a set of Irwin grip sockets and that worked a treat! Only problem was it took the head clean off the bolt, but I could then get to and remove it. Both sides now blanked and what a difference Thumbs Up Definately something to look into if you have a pre-2007 Rrs.
Post #351968 Fri Jul 27 2012 7:07am
mikey7985
No worries Thumbs Up
Have you noticed a power/Economy increase?? Very Happy 2009 3.6 TDV8 HST
Post #352046 Fri Jul 27 2012 5:36pm
Tony666
Mpg gone from 26 to 28 for a mixture of urban and motorway/a roads. Definately increase in responsiveness, used to get intermittent flat spots when pulling off, much better now
Post #352118 Sat Jul 28 2012 11:40am
mikey7985
I read another thread about 2 different methods one being blanking and the other being removal and blanking.
I thought you had to remove the EGR regardless?? 2009 3.6 TDV8 HST
Post #352147 Sat Jul 28 2012 9:08pm
Tony666
I'm no expert but from what I can gather you have 2 options, blanking which just involves removing 4 bolts, then inserting a blanking plate and replacing bolts or full removal which completely removes valves and pipe work. It's my understanding that the end result is identical but the blanking method is cheaper and easier....just be prepared for rusty bolts!!! Full instructions for both methods are available online
Post #352155 Sat Jul 28 2012 9:47pm
mikey7985
Thanks Tony, Might just be me being fussy but I think I would want them out completely.
Do you need tha same kits for both options then? Dont suppose you have a link for those instructions do you?
Thumbs Up 2009 3.6 TDV8 HST
Post #352157 Sat Jul 28 2012 9:53pm
Tony666
Check out bell auto services for the full removal kit, seems popular with people on this forum. A bit more kit than just a pair of blanking plates but it depends on which option you want. Full fitting instructions on BAS website. If you just want blanking plates search for 2.7tdv6 blanking on e-bay. Thumbs Up
Post #352180 Sun Jul 29 2012 1:16pm
mikey7985
Thanks Tony Thumbs Up 2009 3.6 TDV8 HST
Post #352190 Sun Jul 29 2012 4:15pm
