| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Surely it shouldn't be this bad!!! |
| Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539      | You have a LR customer care member now, well done Tony   | ||
|  Fri Jul 20 2012 2:23pm |
| Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208    | Tony, it's fairly normal for these to corrode, I bought a few of them, and replaced them when I changed an EGR valve a few weeks back, I put some copperslip on the new ones, in case I ever have to remove them again,(fairly likely  | ||
|  Fri Jul 20 2012 8:03pm |
| Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170    | Thanks for that, just picked some up from my local friendly Stratstone in Cardiff, took 3 calls and 25 mins on hold to establish if they had some and then charged 4 x the price that they were available online for (same manufacturer), cheers Landrover   | ||
|  Sun Jul 22 2012 7:48am |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Agreed this is fairly common Mike
|  Sun Jul 22 2012 11:16am |
| mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111      | Can you not spot weld another nut or somthing onto that rounded one? 2009 3.6 TDV8 HST | ||
|  Tue Jul 24 2012 10:22pm |
| Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170    | Thanks for the advice but space is a bit tight and I have neither the knowledge or equipment for welding  | ||
|  Fri Jul 27 2012 7:07am |
| mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111      | No worries   | ||
|  Fri Jul 27 2012 5:36pm |
| Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170    | Mpg gone from 26 to 28 for a mixture of urban and motorway/a roads. Definately increase in responsiveness, used to get intermittent flat spots when pulling off, much better now | ||
|  Sat Jul 28 2012 11:40am |
| mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111      | I read another thread about 2 different methods one being blanking and the other being removal and blanking.
|  Sat Jul 28 2012 9:08pm |
| Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170    | I'm no expert but from what I can gather you have 2 options, blanking which just involves removing 4 bolts, then inserting a blanking plate and replacing bolts or full removal which completely removes valves and pipe work. It's my understanding that the end result is identical but the blanking method is cheaper and easier....just be prepared for rusty bolts!!! Full instructions for both methods are available online | ||
|  Sat Jul 28 2012 9:47pm |
| mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111      | Thanks Tony,  Might just be me being fussy but I think I would want them out completely.
|  Sat Jul 28 2012 9:53pm |
| Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170    | Check out bell auto services for the full removal kit, seems popular with people on this forum. A bit more kit than just a pair of blanking plates but it depends on which option you want. Full fitting instructions on BAS website. If you just want blanking plates search for 2.7tdv6 blanking on e-bay.   | ||
|  Sun Jul 29 2012 1:16pm |
| mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111      | Thanks Tony   | ||
|  Sun Jul 29 2012 4:15pm |
| Posting Rules
 ). Pt no for these bolts is RYG500220 for a 55 plate (same as mine).
 Still trying to get one of the rusted rounded bolts out, made a right mess of it, anyone used any of the 'Grip Sockets' for rounded bolts before??
 Still trying to get one of the rusted rounded bolts out, made a right mess of it, anyone used any of the 'Grip Sockets' for rounded bolts before?? I ordered a set of Irwin grip sockets and that worked a treat!  Only problem was it took the head clean off the bolt, but I could then get to and remove it. Both sides now blanked and what a difference
