![]() | Home > Maintenance & Modifications > 60K Service Cost |
Surely you must have a friend who knows what he is doing can give you a hand changing the brakes for a few beer tokens |
The sceptic in me says this is why they were £420. Have you verified the work does indeed need doing? ON THE WAY: BMW F21 M140i
Bc, when you have wiped the sleep out of your eyes, |
Ah Bc you have now woke up just before i'd finished posting |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
At LR main dealer rates I reckon that's about 2 hours labour. |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Both local indy and LR quoted 4 hours work and both priced the same ![]() |
Send jordan @ Overfinch a pm and ask him if he has any kicking around |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
if they are the ones im thinking of,on your door step, I would double check the work needed doing, as my brakes wore down very quickly on my old car according to them and i just got them to do it. But then heard of others falling for the trap of over zealous measurements on there brakes and later seeing the parts and there been loads of life left in them |
try sponsors Pete at BAS or greenoval |
NPinks, not the dealer you are thinking of, i would not send my daughters bike there. ![]() The disks are due change after 60K and it had a second pair of Brembo pads at 30K so all is about right and i should change the pads at the same time as new disks, the issue on the back is i believe a seized caliper as drivers side rear pad is at 5mm and N/S is at 2mm so excessive wear on this one alone. |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
hello leedsunited
Shepp, many thanks for the info, hopefully when the dealer puts the new pads in he will give it a clean. |
Good old NPinks comes up trumps again, Green Oval £90, booked in ![]() |
