Home > Maintenance & Modifications > 60K Service Cost
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
60K Service Cost
So just had a 60K and whilst shopping around for prices I could not believe the spread, Land Rover dealers went from £600 at the most expensive down to £420 as the cheapest with an independent coming in at £250, went for the £420 as it was on the doorstep and could collect. following service they report needing new front disks and pads, rear pads uneven wear and suspected rear passenger side caliper stuck, have all the parts in my garage but they want £180 to do the work Shocked
Post #350836 Mon Jul 16 2012 8:32pm
Surely you must have a friend who knows what he is doing can give you a hand changing the brakes for a few beer tokens Thumbs Up
Post #350850 Mon Jul 16 2012 10:03pm
The sceptic in me says this is why they were £420. Have you verified the work does indeed need doing? ON THE WAY: BMW F21 M140i
Post #350882 Tue Jul 17 2012 8:36am
Bc, when you have wiped the sleep out of your eyes, Yawn read it again Rolling Eyes The service was £420 Thumbs Up and the price they quoted for fitting the brakes only (labour) is £180 Embarassed
Post #350885 Tue Jul 17 2012 8:53am
Ah Bc you have now woke up just before i'd finished posting Laughing
Post #350886 Tue Jul 17 2012 8:54am
Laughing all awake here Ady.......maybe it's too early for you back there in the UK Wink ON THE WAY: BMW F21 M140i
Post #350887 Tue Jul 17 2012 9:01am
Bradders
At LR main dealer rates I reckon that's about 2 hours labour. Evil or Very Mad
My local back street garage fitted new pads all round on my FL2 a couple of years ago for £50 in notes and I doubt popping on discs as well should cost much more than that. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #350895 Tue Jul 17 2012 9:58am
leedsunited
Both local indy and LR quoted 4 hours work and both priced the same Shocked Oh and if needed does anybody know where i can get a new caliper that will not cost the earth?
Post #350918 Tue Jul 17 2012 1:31pm
Send jordan @ Overfinch a pm and ask him if he has any kicking around Thumbs Up
Post #350927 Tue Jul 17 2012 3:16pm
if they are the ones im thinking of,on your door step, I would double check the work needed doing, as my brakes wore down very quickly on my old car according to them and i just got them to do it. But then heard of others falling for the trap of over zealous measurements on there brakes and later seeing the parts and there been loads of life left in them
Post #350928 Tue Jul 17 2012 3:40pm
try sponsors Pete at BAS or greenoval Idea
Post #350930 Tue Jul 17 2012 3:41pm
leedsunited
NPinks, not the dealer you are thinking of, i would not send my daughters bike there. Shocked
The disks are due change after 60K and it had a second pair of Brembo pads at 30K so all is about right and i should change the pads at the same time as new disks, the issue on the back is i believe a seized caliper as drivers side rear pad is at 5mm and N/S is at 2mm so excessive wear on this one alone.
Post #350940 Tue Jul 17 2012 5:17pm
shepp
hello leedsunited
to unseize the rear calipers is a very easy job, it is the floating knuckle that seizes not the piston, It shouldnt even require the whole caliper removing, just as clean and a regrease, and maybe ,(if damaged) a new pair of rubber gaiters.
Post #350943 Tue Jul 17 2012 5:48pm
leedsunited
shepp wrote:
hello leedsunited
Shepp, many thanks for the info, hopefully when the dealer puts the new pads in he will give it a clean.
Post #350944 Tue Jul 17 2012 5:53pm
leedsunited
Good old NPinks comes up trumps again, Green Oval £90, booked in Thumbs Up
Post #351067 Wed Jul 18 2012 6:56pm
