![]() | Home > Maintenance & Modifications > Timed Climate - upgrade |
Is this from BAS or LR direct, also, how much and is it activated on the screen ?
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
Dont hold your breath on the screen control BC
rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216 ![]() ![]() |
Fob £30 from ebay - same as the one from BAS or LR
Ah, I now understand your post Steuart in James' LPR A/B thread |
Update - had the side panel of the inside of the boot (surprised how easy they come off) and fitted the receiver and connected the antenna, not sure where the other end of the antenna goes to to be honest, looks like it wants to fit to the roof aerial
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Will this work as an aircon when engine not running (i.e. to make the car cool when stationary)? |
so I'm lead to believe (the word climate made me think that) other wise its just going to be used to heat the car up when its get snowy or after a rugby game when I'm froze to the bone |
Well I know of the climate control only as a pre-heater therefore surprised when you say that, especially as I am also after an pre-aircon (i.e. set temp and let the the car use the fuel to cool down, same as to heat up). Anyone knows the options? |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Will vent car as well |
Thanks mate ![]() |
The icon on the display is a 'SnowFlake' so would make sense |
Just received this from LR - still no help - looks like I'm taking the car to bits again
Update - the cable supplied by LR was for my car but for a model that has a digital TV tuner fitted, changed it to LR008654 stuck it to the rear of the roof under roof trim.
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Can you confirm the model year this is? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
