Home > Technical > EGRs again
garrycol
Australia
EGRs again
RRS TDV6 07MY with 64,000km - starting the next day after a continuous 1400km trip the check engine light came on - car still runs OK.
ECU codes read
P0490 - EGR Circuit Control
P0405 - EGR Sensor A
P1335 - EGR Position Sensor
P0140A - EGR Sensor C
P1623 - Immobilizer Code Failure
U0164, 0155, 0102 - Lost Communications with A/C system, instruments, Tfr Case
P140E - EGR position sensor C
On clearing the ones that remain are
P0140A - EGR Sensor C - Circuit Low - General Signal Failure.
The engine check light has gone out but did come back on once and then removed.
I take it that EGR Sensors A and C are basically the sensors in each of the EGRs.
So I can assume that my EGRs are on the way out?
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #347501 Tue Jun 19 2012 4:12am
Texstar
Yes, I'm afraid so, (common problem), I have just changed the L/H valve(viewed from drivers seat) on mine,which had faults showing sensor 'B' and circuit low 'C'. Previously (3 yrs ago) I had circuit low on 'A' which relates to the R/H valve,which was changed under warranty. Mine was pulling away slower than a snail,(suspect valve sticking open), most disconcerting and bl**dy dangerous at times.........Ok now, but for how long Whistle RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #347586 Tue Jun 19 2012 12:29pm
garrycol
Australia
Thanks Texstar - sad thing is performance is great so must be stuck in the closed position - best blanks out but the engine light comes on. Noticed it only comes on every few starts but not when the car is actually running.
Found a supplier of new ones with gaskets etc for £130 ea for my 07MY. Is there anything I should be looking for when ordering these vaives.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #347599 Tue Jun 19 2012 1:44pm
Texstar
Hi Garry, I went for genuine LR parts from Nick aka 'The Large One' at Yeovil LR Bow down , there is a good guide on how to do this job, by Disco_Mikey http://www.disco3.co.uk/forum/topic31658.html Bow down , I'd recommend (as he does) replacing the torx headed bolts that hold the valve to the cooler with the same hex headed ones(but NEW, of course) that hold the upper pipes to the valves,it does make refitting a little easier. PS mine is an '06, so valves are different p/no's and more expensive Big Cry , discounted to £155 each + gaskets,bolts, p&p. BTW Nick can post to Oz I believe, as yours is not affecting performance at the moment, you could leave it a while I suppose. Thumbs Up RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #347670 Tue Jun 19 2012 7:49pm
garrycol
Australia
Thanks for all that information - followed the posts on doing the job but with piggy fingers and my luck I know all is not going to go well. I am tempted to leave then as is but the orange light on the dash annoys me. Interesting that the fault on shows on start and not when running.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #347723 Wed Jun 20 2012 6:44am
garrycol
Australia
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #347724 Wed Jun 20 2012 6:45am
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
BTW guys, is a symptom of the valve problem a smokey exhaust under throttle? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #347769 Wed Jun 20 2012 10:02am
Texstar
Didn't notice any excessive smoke with mine, it just wouldn't accelerate away even on 3/4 throttle, then after what seemed an eternity Shocked it would take off like a scalded cat. Have you checked the intercooler hoses for splits / delamination:?: RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #347771 Wed Jun 20 2012 10:18am
sherlock
No I haven't. It's with LR today to determine the fault. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #347772 Wed Jun 20 2012 10:32am
garrycol
Australia
Textars symptoms is what I had for a little while - now just drives normally - I guess if the EGRs are closed no exhaust gets into the engine so it drives normally (like mine is now) however if locked open then gases are going into the engine all the time and it runs like a dog.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #347783 Wed Jun 20 2012 12:28pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Depends how much, but most give out some under acceleration Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #347938 Thu Jun 21 2012 8:59am
