| RRSPORT.CO.UK | ||
|  | Home > Technical > Help with rear ARB bushes |
| panda Member Since: 17 Jan 2010 Location: london Posts: 702    | Sorry don't know about shims but need to do mine, where did you get bushes and how much. Thanks Panda  | ||
|  Wed Jun 06 2012 3:46pm |
| factoryfil Member Since: 02 Feb 2012 Location: Norwich Posts: 26      | fairly sure they are not supposed to have shims, most likely someone has used the shim to pick up slack in the mounting bush maybe instead of fitting a new one, I recently done my bushes and the bar was badly worn and the new mounting bushes took up the play o.k. hope this helps. | ||
|  Wed Jun 06 2012 4:34pm |
| iainp100 Member Since: 05 May 2011 Location: saddleworth Posts: 59    | Cheers guys as for the bushes they are original parts got them from duckworths about 18 pound approx easy to fit just a little tight but ratchet spanner sorted it out Range rover Sport tdv8 with bas touch
|  Thu Jun 07 2012 8:37am |
| Posting Rules
