Home > Technical > Help with rear ARB bushes
iainp100
2007 Range Rover Sport TDV8 HSE Siberian Silver
Guys changed the rear ARb bushes on my car this weekend and when i took the old ones off one had a metals shim in it like a packing plate but the other side did not
Question is are they ment to have the SHIMS or not
If some one can point me in the right direction it would be great
Cheers in advance Range rover Sport tdv8 with bas touch
Landrover discovery4 XS 3.0 tdv6
Landrover discovery3 se 2.7 tdv6 Gone
volvo c70 T5 Gone
leon Cupra 20VT Gone
Post #345994 Wed Jun 06 2012 10:11am
panda
Sorry don't know about shims but need to do mine, where did you get bushes and how much. Thanks Panda
Post #346028 Wed Jun 06 2012 4:46pm
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
fairly sure they are not supposed to have shims, most likely someone has used the shim to pick up slack in the mounting bush maybe instead of fitting a new one, I recently done my bushes and the bar was badly worn and the new mounting bushes took up the play o.k. hope this helps.
Post #346031 Wed Jun 06 2012 5:34pm
iainp100
Cheers guys as for the bushes they are original parts got them from duckworths about 18 pound approx easy to fit just a little tight but ratchet spanner sorted it out Range rover Sport tdv8 with bas touch
volvo c70 T5 Gone
Post #346077 Thu Jun 07 2012 9:37am
