Home > General > Help Help Help
broncoupe
Help Help Help
I have an 05 Supercharged Sport thats the good news,heres the bad news.
Went to start it today turned the key --nothing, turned the key again it fired on crank then cut out
After that every fault HDC, Gearbox indicators came on
I reasoned it was a battery failure.
Bought a new battery fitted it still not starting everthing works in ignition position just no crank accompanied by the indicators flashing.
Suggestions please
Post #342698 Sat May 05 2012 9:37pm
Texstar
Do you mean the hazard lights are on without you selecting them on ? I thought that was an indication(along with not starting) that the car has had an impact of some sort, is that possible? Hope it's not. Shocked RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #342701 Sat May 05 2012 10:50pm
zahid din
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
in any other car that would sound like the cam belt ? rr sports hse 06 cuts out now and then .computer reads engine management failure,engine failuere.help
Post #342702 Sat May 05 2012 10:51pm
broncoupe
hazards come on --on there own was making me wonder if it was an immobilser fault
The engine hasnt locked up this is electrical not mechanical
Post #342704 Sat May 05 2012 11:58pm
broncoupe
Car drove onto the drive sat for 2 days thought its the weekend i would use it Big Cry
Post #342705 Sun May 06 2012 12:00am
broncoupe
update
The car started this morning 3 or 4 turns of the key nothing then it started
Engine runs fine but dash is lite up like a christmas tree ABS Airbag and no rev counter F in speedo for gearbox
HDC fault Suspension lowered also the hazards flash then stop and the door locks trigger then recycle
The only work that the car has had in the last few days is i had the wheels refurbished could they have broken something on the suspension maybe some sort of crash sensor
Big Cry
Post #342712 Sun May 06 2012 10:10am
Sounds like the remote isn't talking the the car properly, intermitent fault, you don't have a brake light out by any chance do you? This fault has been know to through up all kinds of electrical gremlins Confused
Post #342756 Sun May 06 2012 9:11pm
broncoupe
No mate all new plus brake light switch, i recon its canbus related as all these items talk to each other does anyone have a wiring diagram and ecu component locations
Post #342761 Sun May 06 2012 9:41pm
Hmm all new Question I'd have them doubled checked Thumbs Up They might be new but could still be causing the fault, a guy on here had similar problems after changing bulbs, got some more new ones and cleared the fault Confused
Post #342768 Sun May 06 2012 9:56pm
broncoupe
Found some guys in the States went straight to it transfer case wiring high resistance on the can bus wiring
hope this helps someone else
broncoupe
Post #342793 Mon May 07 2012 9:54am
