![]() | Home > General > Help Help Help |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Do you mean the hazard lights are on without you selecting them on ? I thought that was an indication(along with not starting) that the car has had an impact of some sort, is that possible? Hope it's not. |
zahid din Member Since: 21 Apr 2012 Location: birmingham Posts: 8 ![]() ![]() ![]() |
in any other car that would sound like the cam belt ? rr sports hse 06 cuts out now and then .computer reads engine management failure,engine failuere.help |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 62 ![]() ![]() |
hazards come on --on there own was making me wonder if it was an immobilser fault
Car drove onto the drive sat for 2 days thought its the weekend i would use it ![]() |
The car started this morning 3 or 4 turns of the key nothing then it started Engine runs fine but dash is lite up like a christmas tree ABS Airbag and no rev counter F in speedo for gearbox HDC fault Suspension lowered also the hazards flash then stop and the door locks trigger then recycle The only work that the car has had in the last few days is i had the wheels refurbished could they have broken something on the suspension maybe some sort of crash sensor ![]() |
Sounds like the remote isn't talking the the car properly, intermitent fault, you don't have a brake light out by any chance do you? This fault has been know to through up all kinds of electrical gremlins |
No mate all new plus brake light switch, i recon its canbus related as all these items talk to each other does anyone have a wiring diagram and ecu component locations |
Hmm all new |
Found some guys in the States went straight to it transfer case wiring high resistance on the can bus wiring hope this helps someone else broncoupe |
