Home > Technical > Front Lights - Halogen vs Bi Xenon Light Housings
garrycol
Australia
My RRS has halogen lights. Looking at the back of the housing it looks as if the slot where the shutter would have been fitted in the Bi Xenons seems to be there. Can someone tell me whether the basic housings are in fact the same (obviously one without the shutter) and whether the lens in the headlight is the same in both headlight housings.
I am thinking about replacing the low beam halogens with single beam HIDs but want to investigate relevant issues first.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #340779 Sat Apr 21 2012 10:52am
garrycol
Australia
Bump 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #340952 Mon Apr 23 2012 2:21am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Hi Garry,
I think that the reflectors are a different shape for Halogen V's HID as one has a point source of light and the other issues the light from a greater area in the globe.
You often see cars that have had HID fitted to the standard reflectors and they spray bright HID type light all over the place dazling oncoming drivers. Not good.
Regards
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #340956 Mon Apr 23 2012 4:17am
Bobby
Garry,
I would think that the housing of all 3 different headlights (Halogen, Bi-Xenon or Adaptive Front lighting System) are the same and I am sure the headlamps share a common, clear lens.
Regarding replacing the low beam halogens, please remember that you have a combination Bi-halogen low/high beam headlamp and replacing it with a single HID.....?
Hopefully these drawings will help you...
Halogen Headlamp
Bi-Xenon Headlamp
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #340957 Mon Apr 23 2012 4:36am
garrycol
Australia
Barry - thanks for your input - I suspect you are right and the reflectors are different but not sure.
Bobby - thanks for the information and highlighting that the halogens are like the Bi Xenons in that they are Bi Halogens - I didn't know that.
If I cannot find out if the reflectors are the same (I suspect they are different) then the lights will stay halogens. I will replace the globes with better units though.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #340965 Mon Apr 23 2012 8:25am
Bobby
Garry, I found this description...
Quote:
The mono-halogen low beam only headlamp uses a projector lens, similar to the xenon headlamp. The projector module comprises an ellipsoidal lens and a reflector. The projector reflector collects the light produced by the halogen bulb and projects the light into a focal plane containing a shield. The contour of the shield is projected onto the road by the lens.
 Malaysia Boleh!
Post #340987 Mon Apr 23 2012 12:26pm
garrycol
Australia
Thanks 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #340992 Mon Apr 23 2012 1:17pm
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
Hi Gary, I have replaced the standard halogen lamps with a hid conversion kit on a RRS 06 YM, but only on the dipped beam,(massive improvement)main beam seemed o.k. as is. There is room for the discharge unit on the bottom of the headlamp casing, it might be worth trying to find a kit with metal bulb bases as the plastic base bulbs are too thick for retaining clips, hopes this helps
Post #341429 Wed Apr 25 2012 11:41pm
garrycol
Australia
Thanks for your information - was your low beam a combined low beam/hi beam bulb as mentioned above? I am just concerned about the light spread if I just replace the halogen bulb with a HID one - hence my question on reflectors and lens for halogen vs Xenon housings.
Here in Aust HIDs are illegal where not fitted as OEM equipment so I do not want to attract attention to myself. If the housing, reflectors etc are basically the same for both versions then all is OK.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #341434 Thu Apr 26 2012 2:54am
factoryfil
Garry, the headlamps i converted were halogen dipped and main, I only converted dipped beam, they are single filament bulbs (H7), the dipped does stay on with high beam as with most vehicles, projector style headlamps work well with HID bulbs, basically non bi- xenons oem headlamps are projector lamps with self leveling devises,(dipped beam that is), I don't know whats involved to convert main beam, the halogen mains seem o.k. anyway
Post #341444 Thu Apr 26 2012 10:24am
