![]() | Home > Technical > Front Lights - Halogen vs Bi Xenon Light Housings |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
My RRS has halogen lights. Looking at the back of the housing it looks as if the slot where the shutter would have been fitted in the Bi Xenons seems to be there. Can someone tell me whether the basic housings are in fact the same (obviously one without the shutter) and whether the lens in the headlight is the same in both headlight housings.
Bump 07MY RRS TDV6
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Hi Garry,
Barry - thanks for your input - I suspect you are right and the reflectors are different but not sure.
Garry, I found this description...
Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thanks 07MY RRS TDV6
factoryfil Member Since: 02 Feb 2012 Location: Norwich Posts: 26 ![]() ![]() ![]() |
Hi Gary, I have replaced the standard halogen lamps with a hid conversion kit on a RRS 06 YM, but only on the dipped beam,(massive improvement)main beam seemed o.k. as is. There is room for the discharge unit on the bottom of the headlamp casing, it might be worth trying to find a kit with metal bulb bases as the plastic base bulbs are too thick for retaining clips, hopes this helps |
Thanks for your information - was your low beam a combined low beam/hi beam bulb as mentioned above? I am just concerned about the light spread if I just replace the halogen bulb with a HID one - hence my question on reflectors and lens for halogen vs Xenon housings. Here in Aust HIDs are illegal where not fitted as OEM equipment so I do not want to attract attention to myself. If the housing, reflectors etc are basically the same for both versions then all is OK. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Garry, the headlamps i converted were halogen dipped and main, I only converted dipped beam, they are single filament bulbs (H7), the dipped does stay on with high beam as with most vehicles, projector style headlamps work well with HID bulbs, basically non bi- xenons oem headlamps are projector lamps with self leveling devises,(dipped beam that is), I don't know whats involved to convert main beam, the halogen mains seem o.k. anyway |
