Home > Maintenance & Modifications > Various Topics.
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Various Topics.
Hi Guys
First post so be gentle with me,I bought a 06 plate Sport last November which now has 58000 miles and have a few questions I hope that you can possibly help me with. Firstly on overrun or stopping at junctions and pulling away I seem to have what feels like backlash/slight slack through the drive before it picks up again.I have been told it might be worth changing gearbox oil and filter or it could be bottom front suspension arm bushes,can anyone advise .If the bushes are away is it worth renewing with poly bushes .Has anyone had to change the mounting bush on transfer box or the rear diff mounting bushes if so can these be done with poly bushes.
Timing belts I have been told these dont need done till 120000 is this true or is there also a time ie 6/7years.
Finally for now my car has the Dynamic Response and I would say I probably get a bit of rattling in a straight line. Are the latest Bulletins for Land Rover a recall notice.
Sorry about all the questions Jock. Confused
Post #339861 Sat Apr 14 2012 12:50pm
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Is It not 105000 or 7 ish years Thumbs Up 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
L.E.D. lights throughout.
Post #339865 Sat Apr 14 2012 1:27pm
Jock 77
Various Topics
Thanks Ken .Any other help would be much appreciated.
Post #339873 Sat Apr 14 2012 2:58pm
Jock, try using the command shift on approach to a junction, when you have almost stopped put it into 1st gear then see if it pulls away better without the backlash you have described, the problem is that a rrs pulls away in second gear in auto which give it a sluggish take off by using the command shift you get to pull away a lot quicker but don't forget to change up the gears if using command shift otherwise it will hit the rev limiter and change up itself Thumbs Up
Post #339877 Sat Apr 14 2012 3:27pm
Strathearn Engineering
Correct, 105k miles or 7 years, whichever comes first Thumbs Up Strathearn Engineering
Specialising in all things Land Rover + Range Rover
2010MY Range Rover Sport HSE for sale
Group Buy - TDV6 + TDV8 Re-Maps!
TDV6 Silicone Turbo Hose kits for sale
RRS Brake Sale Special Offer!
Post #339891 Sat Apr 14 2012 5:45pm
Jock 77
Various Topics
Thanks again for the replies so far.
Post #339892 Sat Apr 14 2012 5:52pm
Jock 77
Various Topics
Thanks again for the replies that I have already received.Tried the command shift but never made much difference ,just wondered if anyone had any other thoughts on my queries. The other thing I had wanted to ask is does anyone have any recommendations where in Scotland to have the Timing Belts changed.I know it will be next year but as well to get organised Smile
Post #339929 Sun Apr 15 2012 11:22am
We can replace the timing belts only for £300 + VAT, or replace the belts, idler pulleys, and aux belt for £350 + VAT Smile Strathearn Engineering
Post #339939 Sun Apr 15 2012 12:55pm
Jock 77
Various Topics.
Thanks Strathearn will definately keep that in mind for the Belts. Or any other major stuff. Can you help on the other queries ie the slack in the drive or about the Poly bushes and if the possible cure for the rattle from the Dynamic Stability control is this a recall ?
Post #339951 Sun Apr 15 2012 4:05pm
The slack in the drivetrain, we would need to see the car to assess it.
The rattle from the Dynamic Response system could just be worn bushes. Again, we would need to see the car and have a look over it
We also tend to replace complete wishbones. By the time you take into account a set of standard bushes and a ball joint, + the labour to replace the bushes, we find it is more cost effective to just replace the arm complete.
We have never fitted a set of polybushes to a Disco 3 or RRS as yet, as they tend to cause a lot of problems until the bushes wear slightly, and loosen off a bit. That, and cost. A front wishbone bush kit, and a pair of balljoints cost about the same as a pair of wishbones, before any labour is taken into consideration...
Hope that helps Thumbs Up
Mike Strathearn Engineering
Post #340024 Mon Apr 16 2012 6:43am
Jock 77
Various Topics
Thanks again to Strathearn.I will try and have a better look over the car and see what I come up with.If I am passing though might well pop in and say hello if thats ok. Cheers
Post #340324 Wed Apr 18 2012 12:53pm
