| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Blanking EGR valves on 08 sport |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Snowski, Glad you got the kit fitted ok. MPG is not normally worse from blanking the EGR's and some report a gain, However if the garage has done a hard driving road test before handing you the car back it could show low for the next few miles untill it settles with your normal driving again.
|  Fri Mar 23 2012 8:31pm |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Pete.
|  Sat Mar 24 2012 9:38am |
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106  | @D4jww,
|  Tue Mar 27 2012 3:54am |
| D4jww Member Since: 08 Feb 2012 Location: London Posts: 18  | Yes and it's a big frustration p0402 appear and then 4 other codes( all relating to loosing coms with engine ecu)that gives 4 warning lights and then suspension lowering as explained in my post http://www.disco3.co.uk/forum/topic77360.html
|  Sun Apr 01 2012 8:02am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | I am pretty sure I read on a Jag forum that they uses a 7mm hole, however I think that is with one EGR valve, so if you are drilling holes in 2 EGR valve then i would assume you would need 2 hole with half the area of the 7 mm hole.
|  Sun Apr 01 2012 9:18am |
| D4jww Member Since: 08 Feb 2012 Location: London Posts: 18  | Thanks SRE, can you remember if that's in the erg blanking plate or the Buttefly valve? Because I would want to avoid hole in the blanking plate, because the objective with this mod was to avoid exhaust gasses going back into the inlet manifold.   | ||
|  Sun Apr 01 2012 12:27pm |
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106  | Do you only get the code P0402, or also the check engine light? RRS SDV6 HEV Dynamic
|  Sun Apr 01 2012 12:39pm |
| D4jww Member Since: 08 Feb 2012 Location: London Posts: 18  | No engine management light, just p0402! Maybe my vin 9A499*** has got something to do with it, the spesial lowering suspension safety feature  | ||
|  Sun Apr 01 2012 12:51pm |
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106  | Just having the code isn't any issue, or is there? RRS SDV6 HEV Dynamic
|  Sun Apr 01 2012 12:57pm |
| D4jww Member Since: 08 Feb 2012 Location: London Posts: 18  | No got 5 other DTC all intermitted and basicly loosing comms with engine ECU see summary http://www.disco3.co.uk/gallery/displayima...amp;pos=27
|  Sun Apr 01 2012 1:02pm |
 Now your asking, I think it was in the blanking plate, I will have to do a little googleing, see if I can find it again. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. | ||
|  Sun Apr 01 2012 1:05pm |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Photo on here of plate with hole in
|  Sun Apr 01 2012 1:16pm |
|  Sun Apr 01 2012 1:29pm |
 Ok, than you are fine with the EGR blanking, I think I also got the P0402 (will check again later), but no check engine light, and no change in behavior, so all is well. Have no idea what could be wrong with the Suspension issue, here a summary of the codes: ABS & Air suspension U0401 : Invalid Data Received from ECM/PCM A - Event information: Check ECU for errors Terrain Response : U0416 : Invalid Data Received From Vehicle Dynamics Control Module, Check ABS for Errors Instrument: U0132: Lost Communication With Suspension Control Module "A" - Missing message, Check Ride Level Control Module Body Control : B1D17 : Lost communication with BBUS (Battery Backed Sounder) I can check what ECU software I have, but I don't think it will help here. RRS SDV6 HEV Dynamic XKR 700 BHP with Twin-screw and LSD | ||
|  Sun Apr 01 2012 1:45pm |
| Posting Rules
