Home > Technical > Resetting Parking sensors
Tiny Timmy
Can anyone tell me how you reset parking sensors on a 2005 RRS ?
Post #336052 Sat Mar 10 2012 8:59pm
scarey
dont think you can...if you have any electrical problems sometimes discounting the battery works..
Post #336060 Sat Mar 10 2012 10:41pm
Bobby
Why do you need to reset? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #336074 Sun Mar 11 2012 1:29am
Tiny Timmy
I thought it may help as everytime I put it in reverse it goes off a continuous beep, Ive cleaned them all and it still does it!!
Post #336087 Sun Mar 11 2012 9:51am
Bobby
There's nothing to reset, as mentioned above by scarey.
There could be a number of reasons, most of which will bring up a DTC. In the absence of this, there is also the
On-board self-test:
This self-test will inform the driver of any faults by a combination of LED and tones:
a) The status LED will flash if the system is active and a fault is detected in the sensors, sounders, wiring or module;
b) The front sounder will emit an error tone for 3 seconds if a fault is detected with the front sensors or if the rear sounder develops a fault;
c) The rear sounder will emit an error tone for 3 seconds if a fault is detected with the rear sensors, the switch, or the LED in the switch, or if there is a controller area network (CAN) bus error.
Do a search, this has been discussed before. Malaysia Boleh!
Post #336141 Mon Mar 12 2012 2:21am
BulletProofBomb
[quote="Bobby"]There could be a number of reasons, most of which will bring up a DTC.[quote]
DTC???
I've got the same problem and couldnt find anything helpful on a search. RRS TDV8 (loving it)
Suzuki Bandit 1200 (For when the suns out)
Nissan 350z GONE
Post #336142 Mon Mar 12 2012 3:06am
Bobby
Diagnostic Trouble Code can appear on the message centre and/or they can be retrieved with a proper diagnostic system tool. Malaysia Boleh!
Post #336144 Mon Mar 12 2012 4:25am
BulletProofBomb
Thanks Bobby, no flashing lights or 3 second tones for me, so off th the dealers I go. RRS TDV8 (loving it)
Nissan 350z GONE
Post #336145 Mon Mar 12 2012 4:26am
Tiny Timmy
I am going to try changing Sensors first and go from there..........cheers............ Confused Confused
Post #336187 Mon Mar 12 2012 12:21pm
BulletProofBomb
@ Tiny Timmy,
I remember reading on hear somewhere if you put the car into reverse and put your ear up to each sensor you can hear the one thats not working making a slight buzzing noise, thats if its the sensor that is actually faulty. RRS TDV8 (loving it)
Nissan 350z GONE
Post #336267 Mon Mar 12 2012 8:08pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
BulletProofBomb wrote:
@ Tiny Timmy,
Hand brake on and some one with a heavy foot on the brake? Whistle Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #336280 Mon Mar 12 2012 9:16pm
BulletProofBomb
H&S? Pahhh, I done it on my hands and knees crawling after the car as it rolled down the road. I believe one calls it "Ghost riding the whip" Laughing RRS TDV8 (loving it)
Nissan 350z GONE
Post #336281 Mon Mar 12 2012 9:21pm
Tiny Timmy
Thanks Bulletproofbob ill give it a run Worth a try! Smile ...............TT
Post #336317 Tue Mar 13 2012 8:25am
