Home > Technical > Fluctuating Revs at constant speed
I've had this annoying 100rpm fluctuation when driving at constant speed (noticeable in the 40-50mph zone)
Anyway... the dealer said it might be my map causing confusion in the autobox (not expecting so much torque with the applied throttle position) but I wasn't sold on that diagnostic
so I've been on the Jag forum and they are experiencing the same on some of their 6 speed ZF autoboxes (recognised fault)
To solve it requires a cold re-flash of the box? (a warm one does not work)
Anyone know what a re-flash involves?
I think my BAS interface resets the adaptive gearbox when uploading the map... but this does not seam to solve my prob.
Any comments from the techies before I go back to my dealer? RRS gone
Post #335714 Thu Mar 08 2012 12:43pm
DSL
Sounds like you need to find someone with a Faultmate to reflashed the software. Not unheard of issue for D3s.
Post #335717 Thu Mar 08 2012 12:57pm
cheers DSL Thumbs Up RRS gone
Post #335719 Thu Mar 08 2012 1:02pm
DSL
Have a mooch D3side, quite a few peeps over there with the kit to do that, along with a few other mods that LR brought in on newer models but don't deem us worthy of having. Thumbs Up
Post #335722 Thu Mar 08 2012 1:10pm
you mean turn back to the light side of the path?
Mr. Green RRS gone
Post #335726 Thu Mar 08 2012 1:15pm
DSL
We never turn away pilgrims from The Dark Side!! Plus we'll do you a good deal on a Tarmac driveway. Whistle Whistle
Laughing Laughing Thumbs Up
Post #335727 Thu Mar 08 2012 1:19pm
DSL
Here's one. Whistle http://www.disco3.co.uk/forum/topic74729.html
Post #335813 Thu Mar 08 2012 9:37pm
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
Hi awd man, i've just seen your post, I was going to post the same question myself, my 06 2.7 tdvs fluctuating revs at low speed on light throttle, also a bit lumpy on downshifts at low speed, I done a bit of digging around on this forum and jag and d3 forums and I sort of narrowed it down to possible gearbox related issues, I am fairly sure the auto box fluid had not been changed from new, having now done a double fluid flush (genuine fluid only) and a new filter pan (nightmare to fit) it seems to have fixed it, box is now very smooth and more positive to throttle etc. only done a couple of days ago so fingers crossed, not sure about looking at inj. trims etc as suggested on the d3 forum link, I scanned mine and it had no.2 on low limit but fairly sure there not connected to the surgeing, one way of testing it is I think the torque converter locks out in command shift so the problem seems to go.
Post #336609 Thu Mar 15 2012 12:50am
