![]() | Home > Technical > Fluctuating Revs at constant speed |
I've had this annoying 100rpm fluctuation when driving at constant speed (noticeable in the 40-50mph zone)
cheers DSL |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Have a mooch D3side, quite a few peeps over there with the kit to do that, along with a few other mods that LR brought in on newer models but don't deem us worthy of having. |
you mean turn back to the light side of the path?
We never turn away pilgrims from The Dark Side!! Plus we'll do you a good deal on a Tarmac driveway. |
Here's one. |
factoryfil Member Since: 02 Feb 2012 Location: Norwich Posts: 26 ![]() ![]() ![]() |
Hi awd man, i've just seen your post, I was going to post the same question myself, my 06 2.7 tdvs fluctuating revs at low speed on light throttle, also a bit lumpy on downshifts at low speed, I done a bit of digging around on this forum and jag and d3 forums and I sort of narrowed it down to possible gearbox related issues, I am fairly sure the auto box fluid had not been changed from new, having now done a double fluid flush (genuine fluid only) and a new filter pan (nightmare to fit) it seems to have fixed it, box is now very smooth and more positive to throttle etc. only done a couple of days ago so fingers crossed, not sure about looking at inj. trims etc as suggested on the d3 forum link, I scanned mine and it had no.2 on low limit but fairly sure there not connected to the surgeing, one way of testing it is I think the torque converter locks out in command shift so the problem seems to go. |
