![]() | Home > Technical > decreasing mpg |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Cold weather will definitely be having an effect. |
| Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539
Likewise!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!! Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill Ex - Audi A4 Cab 3.0TDi Quattro Ex - Freelander2 SE TD4 Ex - CRV Auto |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Heated seats, lights, etc etc all kill mpg RRS gone
| RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169
Why would heated seats and lights affect mpg I can understand aircon as it uses engine power for the condensor etc but not the above ! Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone) |
^^^ foe the same reason, they all drain power |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Where do you think the power for the heated seats etc. comes from? 2008 TDV8 - it was a labour of love and is much missed |
Yep. And the FBH must have an impact too, especially if lots of short journeys are made. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
Alternator loads definitely pull power from the engine and therefore effect mpg; also in cold weather frictional losses can be higher will metal shrinkage. I notice the oposite more in the summer (higher mpg) on decent runs where everything is warmed up nicely. |
| Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282
This is happening to me also, showing 27mpg before service now 17mpg after |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Cold weather its self should increase MPG not decrease - given the cooler dense air.
Cooler air should give more power but will also increase drag. I bet they cancel each other out even if they were noticeable in the first place. If you put an energy demand in to the system it has to come from the fuel. You might get some of it from clever alternators that charge under braking and / or hybrid systems but there is always loss in the system. Use energy to heat or light something and that will have an effect on the fuel useage. I think the FBH is the big baddie. Judging by the quantity of exhaust it can produce and the speed with which the coolant is heated, it must be burning fuel at a reasonable rate. Would love to know what its fuel consumption is... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I dont think we were disagreeing - its margins in a car that are small - definitely the lift from more dense air is noticeable.
I run my aircon all year...it's "climate control" after all |
