Home > Technical > decreasing mpg
richyrich70
decreasing mpg
When I bought my 2005 4.4 V8 the display was showing 19.2 mpg average. The car has had a recent service at LR but has been showing average of 16.8 mpg this week. The car has been doing the same sort of runs since I bought it. Would it be the cold weather? Any other ideas? Also, it takes an age for the heater to kick out any decent heat.
Post #330995 Sat Feb 04 2012 11:02am
Cold weather will definitely be having an effect. Sad
Have seen mine drop over the last couple of days by 1-2 mpg. ON THE WAY: BMW F21 M140i
Post #330998 Sat Feb 04 2012 11:55am
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Likewise!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #331000 Sat Feb 04 2012 12:10pm
Heated seats, lights, etc etc all kill mpg RRS gone
Post #331069 Sat Feb 04 2012 11:01pm
RRS-Spy
Why would heated seats and lights affect mpg Confused
I can understand aircon as it uses engine power for the condensor etc but not the above ! Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #331072 Sat Feb 04 2012 11:21pm
^^^ foe the same reason, they all drain power Sad
I imagine the FBH also has a slight effect too as recently it's been in action every time I've driven somewhere Confused ON THE WAY: BMW F21 M140i
Post #331078 Sat Feb 04 2012 11:51pm
Where do you think the power for the heated seats etc. comes from? Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #331091 Sun Feb 05 2012 1:33am
Yep. And the FBH must have an impact too, especially if lots of short journeys are made. 2012 SDV6 - it's missing a couple of cylinders
Post #331092 Sun Feb 05 2012 1:33am
Supacat
Alternator loads definitely pull power from the engine and therefore effect mpg; also in cold weather frictional losses can be higher will metal shrinkage. I notice the oposite more in the summer (higher mpg) on decent runs where everything is warmed up nicely.
Post #331128 Sun Feb 05 2012 12:29pm
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
This is happening to me also, showing 27mpg before service now 17mpg after Big Cry 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
L.E.D. lights throughout.
Post #331131 Sun Feb 05 2012 12:48pm
mse
Cold weather its self should increase MPG not decrease - given the cooler dense air.
And in modern cars the impact of additional load shouldnt be noticeable
However, the additional load will be noticeable on shorter journeys and FBH will nock a few MPG out of the systems Mike
2014 Facelift Discovery
Post #331374 Mon Feb 06 2012 11:13pm
Cooler air should give more power but will also increase drag. I bet they cancel each other out even if they were noticeable in the first place.
If you put an energy demand in to the system it has to come from the fuel. You might get some of it from clever alternators that charge under braking and / or hybrid systems but there is always loss in the system. Use energy to heat or light something and that will have an effect on the fuel useage.
I think the FBH is the big baddie. Judging by the quantity of exhaust it can produce and the speed with which the coolant is heated, it must be burning fuel at a reasonable rate. Would love to know what its fuel consumption is... 2012 SDV6 - it's missing a couple of cylinders
Post #331385 Tue Feb 07 2012 1:40am
mse
I dont think we were disagreeing - its margins in a car that are small - definitely the lift from more dense air is noticeable.
But as we both said - FBH and short journeys (where the fuel into the DPF is highest) will kill you mpg not electrical load.
i bet if you compared normal summer use at points with winter - ignoring the heated screens/seats the use would be similar as i bet most of us run ac in the summer Mike
Post #331473 Tue Feb 07 2012 4:59pm
I run my aircon all year...it's "climate control" after all Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #331525 Tue Feb 07 2012 8:24pm
