Home > Faults & Fixes > Blanking EGR valves on 08 sport
Page 2 of 6 <123456>
garrycol
Australia
Mike waldie wrote:
Is yours still running fine?? Mine still going strong
Mike - can you let us know if anything changes. Most people think about blanking when the EGRs have failed and with earlier Vins put on blanks when the EGRs have failed as a cost saving exercise.
Maybe the clue to yours working is the fact you also replaced the EGRs as well so maybe blanks do work as long as the egrs also work - maybe their sensor is more critical than the sensor that detects whether gas comes through to the engine.
Did you use blanks on the EGR or on the inlet port?
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #330233 Tue Jan 31 2012 1:26am
Mike waldie
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi Garry I have no idea what blanks he used, the only thing he said was he spoke to his guy from land rover and he was promised it would work and I would NEVER have a problem with the EGR valves again. It's been a few weeks and still all fine
Post #330235 Tue Jan 31 2012 3:54am
avos
@Mike,
can you lets us know your VIN, this will help in determining which cars will possibly work and which not.
Mine is still running fine, not even pending codes.
@Garry,
You must leave the EGRs attached as they need to function, otherwise you get loads of codes. Why the ECU is not monitoring the actual flow (via the MAP sensor) beats me, as this is what the ECU should do. Maybe it is the latest ECU software that disables it.
It would help if others report there vin and ecu software level where it has failed to blank them off, we might get to the bottom of it. RRS SDV6 HEV Dynamic
XKR 700 BHP with Twin-screw and LSD
Post #330237 Tue Jan 31 2012 6:30am
Mike waldie
Vin on mine is SALLSAA138A158xxxx Hope this helps
Post #330292 Tue Jan 31 2012 1:03pm
Mike waldie
Still all good with no codes
Post #330300 Tue Jan 31 2012 1:20pm
avos
So far also my car is running fine. We may establish a range of cars that can be blanked of, so at least 8A123xxx and 8A158xxx are so far fine.
It would also be interesting to learn which cars did got errors back; maybe B.A.S. can chime in here? I have looked for posts, but I am missing which codes have been generated in them and without that info you can't say if blanking it of or not was the cause.
PS have now ordered a methanol kit, so that it will take care of the cleaning part of the intake. Only side effect is that you get more power, but he you can't have it all Wink. RRS SDV6 HEV Dynamic
Post #330303 Tue Jan 31 2012 1:31pm
Mike waldie
How much are those kits and where did you get yours???
Post #330413 Tue Jan 31 2012 10:34pm
avos
Am no expert on this so it is also a trail for me (with prime purpuse to cleanup inside), but choose the Stage 3 kit from cooling mist:
http://www.coolingmist.com/pagedisplay.asp...urbo_kits,
There are other brands and cheaper kits, but I was charmed about the 2 nozzle setup amongst others. RRS SDV6 HEV Dynamic
Post #330432 Wed Feb 01 2012 4:15am
avos
So far I have not noted any (pending) codes, am still puzzled as to why the P0401 is not popping up.
Have found some more detailed info about how the ECU measures the EGR operation for the Jaguar version (same engine/ECU):
I will try the coming week to do more/longer decelerations also from higher speeds as the ECU will only check the flow on decelerations.
@Mike
Could you do the same? You need to let off the gas and let the car rollout. When I see the table the duration of the deceleration should be at least 4.6 seconds. RRS SDV6 HEV Dynamic
Post #331402 Tue Feb 07 2012 8:35am
D4jww
Being a my08D3 owner, I am watching this tread with great interest, please keep us updated!
Post #331683 Wed Feb 08 2012 6:17pm
Mike waldie
Being doing that bud, letting it roll etc and still the same!!!! Car running great so maybe sorted. Only probs I'm having is my front bushes I think, got knocking noise on small bumps.
Post #331841 Thu Feb 09 2012 6:12pm
D4jww
Might just be arb bushes have you had the sims fitted already or is that just D3's?
Post #332138 Sun Feb 12 2012 5:53pm
Mike waldie
Still running fine guys.. It defo can be done...
Post #332926 Sat Feb 18 2012 9:53am
SRE
Spain
Any chance you can post some more info, e.g what blanks did you use etc.
I am interested as my VIN SALLSAA148A16####
Syd In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #332931 Sat Feb 18 2012 10:33am
avos
So far also here everything is fine, am still puzzled actually as to why.
There is a side effect though, I seem to be getting about 2 to 3 mpg more
I have bought the blanking kit from bas, but any will do... RRS SDV6 HEV Dynamic
Post #334058 Mon Feb 27 2012 6:50am
