![]() | Home > Faults & Fixes > Blanking EGR valves on 08 sport |
| Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147
I guess by no response it's not possible??? My RAC buddy thinks it is and hopefully is doing on tuesday |
| Johnnyopolis Member Since: 12 Aug 2011 Location: Hampshire Posts: 137
Mine is a 2007 and I have had the engine management light on with an EGR valve needed replacing. I was looking at blanking the valve off too. After some research because of EURO4 (or something) you need to have an EGR valve in place. You could blank it off and it would still work but you will have your engine management light up on the dash permanently. Also, as of April any lights on dashboard illuminated that aren't meant to be will fail an MOT. If you take the bulb out they will notice too and it will still fail (not saying you would do this!!) HTH John |
Ta John, hopefully Tuesday I will find out, fingers crossed |
Any EuIV engine (i.e. your car) will have the EML come on if you blank them. As of this year (not sure exactly when, may be end of this year) if an MOT station sees the EML on, it will fail.
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
Have actually managed to blank them of from a EU4 car, well not blank of, but let in metered air (from the engine breather) instead of dirty exhaust... Works like a treat, and of course no engine codes. I might try it on our tdv6 when I have some time. RRS SDV6 HEV Dynamic
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
Bodsy - I was hoping that someone on the techie side was looking at this as an issue for us with newer cars that will come to the problem of sticking valves eventually. Wishful thinking maybe but it would be good if there was an electonic fix, solder in a resistor, etc to allow the light to function on test but go out on start...
Update on mine, my egr valves were faulty so replaced the other week but blanked on one end, car working fine and no light so must be able to be done |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
This goes against all other information - what was done different to normal. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
The ECU is checking if the EGR actually opens via the MAP sensor in the intake. This check is, as far as I know it, done when you decelerate, then the ECU will open up the valves and then close, and during this time it will monitor the vacuum in the intake. When it doesn’t see the expected values, it will throw a P0401, and the check engine light.
My eml light was coming on all the time before they were changed. He also bought a blanking kit as his buddy at land rover said it can be one on 08 car. The car is running fine now |
Very interesting!
I've done a few hundred miles in it now and is used every day. I spoke to my buddy before explaining what people had said on here and he said he checked my chassis number with a 4x4 expert and once new ones were fitted and blanked at one end I would never have a problem with the valves or the light again. |
Very interesting, am curious then how long it will be ok.
Is yours still running fine?? Mine still going strong |
